I downloaded the sdcc compiler for windows of 2.8.0 version from sourceforge and installed in full model,then I typed make in the /Demo/Cygnal directory,but some errors came,
as below:
?ASlink-Warning-Couldn’t find library ‘mcs51’
?ASlink-Warning-Couldn’t find library ‘libsdcc’
?ASlink-Warning-Couldn’t find library ‘libint’
?ASlink-Warning-Couldn’t find library ‘liblong’
?ASlink-Warning-Couldn’t find library ‘libfloat’
ParTest/ParTest.rel: cannot open.
make: *** [main] Error 1
I would guess either the PATH variable was not set correctly (environment variable), or the makefile contains paths that are not correct for your machine.
Actually, I seem to remember that the Cygnal demo needed some libraries to be downloaded from the FreeRTOS site. Check the documentation page for the port to see if there is a link.
I am also having some problems with this demo, however I did get further than this so I’ll try help you out.
On the demo page read the text under the heading "Compiler, header file and library versions", there is a file you need to download, unzip and place in sdcc/lib/large.
You will then need to add "–lib-path c:/sdcc/lib/large" to the make file.
