klvsajay
                (klvsajay)
                    March 27, 2008,  9:15pm
              1
              klvsajay   wrote on Thursday, March 27, 2008 :
Hi, I am trying to compile the sources for Cygnal 8051 port. The steps are given in the port documentation in the website http://www.FreeRTOS.org/portcygn.html
When I follow the exact steps in the website I am encountering the following error.
sdcc -c --model-large -I. -I…/Common/include -I…/include -I…/…/Source/includ
e -DSDCC_CYGNAL --debug --less-pedantic --xram-size 8448 --stack-auto --no-peep
–int-long-reent --float-reent ParTest/ParTest.c
process_begin: CreateProcess((null), sdcc -c --model-large -I. -I…/Common/inclu
de -I…/include -I…/…/Source/include -DSDCC_CYGNAL --debug --less-pedantic --x
ram-size 8448 --stack-auto --no-peep --int-long-reent --float-reent ParTest/ParT
est.c, …) failed.
make (e=2): The system cannot find the file specified.
make: *** [ParTest/ParTest.rel] Error 2
I am unable to understand the makefile. Can someone please help?
Thanking you
Ajay
                rtel
                (Richard Barry)
                    March 28, 2008,  8:43am
              2
              rtel   wrote on Friday, March 28, 2008 :
I have just tried building a clean installation and it seemed to work fine.  Below is my output.  On your system does the file ParTest/ParTest.c exist off the directory in which the makefile is located?  Could it be the version of make you are using is not compatible with the makefile or your system?
Output:
sdcc -c --model-large -I. -I…/Common/include -I…/include -I…/…/Source/include -DSDCC_CYGNAL --debug --less-pedantic --xram-size 8448 --s
tack-auto --no-peep --int-long-reent --float-reent ParTest/ParTest.c
tack-auto --no-peep --int-long-reent --float-reent serial/serial.c
tack-auto --no-peep --int-long-reent --float-reent …/Common/Full/flash.c
tack-auto --no-peep --int-long-reent --float-reent …/Common/Full/print.c
tack-auto --no-peep --int-long-reent --float-reent …/Common/Minimal/integer.c
tack-auto --no-peep --int-long-reent --float-reent …/Common/Minimal/PollQ.c
tack-auto --no-peep --int-long-reent --float-reent …/Common/Minimal/comtest.c
tack-auto --no-peep --int-long-reent --float-reent …/Common/Full/semtest.c
tack-auto --no-peep --int-long-reent --float-reent …/…/Source/tasks.c
tack-auto --no-peep --int-long-reent --float-reent …/…/Source/queue.c
tack-auto --no-peep --int-long-reent --float-reent …/…/Source/list.c
tack-auto --no-peep --int-long-reent --float-reent …/…/Source/portable/MemMang/heap_1.c
tack-auto --no-peep --int-long-reent --float-reent …/…/Source/portable/SDCC/Cygnal/port.c
sdcc --model-large -I. -I…/Common/include -I…/include -I…/…/Source/include -DSDCC_CYGNAL --debug --less-pedantic --xram-size 8448 --stac
k-auto --no-peep --int-long-reent --float-reent main.c ParTest/ParTest.rel serial/serial.rel …/Common/Full/flash.rel …/Common/Full/print.r
el …/Common/Minimal/integer.rel …/Common/Minimal/PollQ.rel …/Common/Minimal/comtest.rel …/Common/Full/semtest.rel …/…/Source/tasks.rel
…/…/Source/queue.rel …/…/Source/list.rel …/…/Source/portable/MemMang/heap_1.rel …/…/Source/portable/SDCC/Cygnal/port.rel
                klvsajay
                (klvsajay)
                    March 28, 2008,  3:46pm
              3
              klvsajay   wrote on Friday, March 28, 2008 :
hi richard,
yes, the partest/partest.c exists in the same folder as that of the makefile.
i am using the gnu make suggested in the freeRTOS website. i downloaded it from http://unxutils.sourceforge.net/
i am not sure of the version of the makefile i am using. can u please forward me the makefile u are using and also the gnu make that u use to run the makefile?
my email address is xxxx@xxxx.com
please send me both the gnu make setup/zip file as well as the makefile you use to compile freeRTOS.
Thanking you
Ajay
                klvsajay
                (klvsajay)
                    April 2, 2008,  7:14am
              4
              klvsajay   wrote on Wednesday, April 02, 2008 :
dear barry,
i used the make file you sent.  it is able to compile a few files and give some output also…this is the output. but it still doesn’t compile completely. pls check the error that is thrown at the bottom.
C:\FreeRTOSV4.4.0\FreeRTOS\Demo\Cygnal>make
ParTest/ParTest.c:171: warning 84: ‘auto’ variable ‘ucBit’ may be used before in
itialization
ParTest/ParTest.c:173: warning 84: ‘auto’ variable ‘ucBit’ may be used before in
itialization
ParTest/ParTest.c:177: warning 84: ‘auto’ variable ‘ucBit’ may be used before in
itialization
–int-long-reent --float-reent serial/serial.c
–int-long-reent --float-reent …/Common/Full/flash.c
–int-long-reent --float-reent …/Common/Full/print.c
–int-long-reent --float-reent …/Common/Minimal/integer.c
–int-long-reent --float-reent …/Common/Minimal/PollQ.c
–int-long-reent --float-reent …/Common/Minimal/comtest.c
…/Common/Minimal/comtest.c:236: warning 84: ‘auto’ variable ‘cByteRxed’ may be
used before initialization
–int-long-reent --float-reent …/Common/Full/semtest.c
–int-long-reent --float-reent …/…/Source/tasks.c
–int-long-reent --float-reent …/…/Source/queue.c
–int-long-reent --float-reent …/…/Source/list.c
–int-long-reent --float-reent …/…/Source/portable/MemMang/heap_1.c
–int-long-reent --float-reent …/…/Source/portable/SDCC/Cygnal/port.c
DSDCC_CYGNAL --debug --less-pedantic --xram-size 8448 --stack-auto --no-peep --i
on/Full/flash.rel …/Common/Full/print.rel …/Common/Minimal/integer.rel …/Comm
/…/Source/tasks.rel …/…/Source/queue.rel …/…/Source/list.rel …/…/Source/p
?ASlink-Warning-Couldn’t find library ‘mcs51’
?ASlink-Warning-Couldn’t find library ‘libsdcc’
?ASlink-Warning-Couldn’t find library ‘libint’
?ASlink-Warning-Couldn’t find library ‘liblong’
?ASlink-Warning-Couldn’t find library ‘libfloat’
ParTest/ParTest.rel: cannot open.
make: *** [main] Error 1
please look at ParTest/ParTest.rel again. I can find this file in the folder after i run make. but it sill throws the error. please look at the sdcc lib errors as well.
pls help
thanks
ajay
                system
                (system)
                    July 31, 2010,  7:37pm
              5
              eoldynski   wrote on Saturday, July 31, 2010 :
I just started tring out FreeRTOS and have a project in mind, based using the 8051 Si Labs( Cygnal)  F120
and have the same problem stated in this post but I haven’t seen any resolution
Has there been a solution posted for this problem?
ed.
                system
                (system)
                    August 27, 2010, 10:35am
              6
              maartenbrock   wrote on Friday, August 27, 2010 :
The error about not found libraries is due to the fact that SDCC does not come with precompiled libraries for the -model-large -stack-auto combination. You need to build them yourself or download them as explained in the article. When using a recent version of SDCC unzip the files into “sdcc/lib/large-stack-auto”.
