I have problem with Cygnal demo compilation. I instaled SDCC, and when I try
build the code i.e make, I see some errors: Parest/ParTest.rel cannot open. All
.rel, .sym, .asm and others files are stored in Cygnal folder, i.e. where
‘make’ is executed.
I use Cygwin.
This might be something as simple as capitalization in the makefile. I run it from a DOS prompt without Cygwin and its compile. Under Cygwin the Unix rules of capitalization and / instead of \ will have to be considered.
