This came up in the last couple of days. Opening the project from an older version of IAR can remove all the proejct options, preventing the code from building and effectively destroying the project.
Download the latest version of the compiler that you are using (beit kickstart, eval or full), then create a fresh FreeRTOS installation (unzip the files again). This should then fix your problem.
