I can’t open the Demo ARM7_AT91SAM7S64_IAR with my IAR Embedded Workbench (4.3). It says the demo is “not a project file”. Which version of the workbench do I require in order to be able to open the demo?
I think it needs to be V4.40, I’m using V4.41. Its annoying that the IAR compiler versions are not often backward compatible! You should be able to update from the IAR WEB site.
