Problem with AT91SAM7S64 Port & IAR V4.20A
peter_mcc wrote on Monday, October 17, 2005:
hi.
I’ve just downloaded FreeRtos V3.2.2 and am trying to get it to work with the IAR KickStart V4.20A (with the patch IAR-Patch64_256_A3_V1.3.zip applied).
When I try to open the workspace it gives an error and says “Not a project file” and that it couldn’t open rtosdemo.ewp
As far as I can tell I’ve got the latest IAR Kickstart package. I’m not sure if I’m doing something wrong or if it just doesn’t work with the IAR version that I have.
regards
Peter
jra01 wrote on Monday, October 17, 2005:
You need to download workbench 4.3, because they’ve apparantly changed the project files somehow.
Jokke
Where can I download it from? Peter
Sorry if the last post sounded rude - it wasn’t meant to!
Looking around again I can see the obvious note about needing V4.30A (I misread it as V4.20A) and where to get it - at least where to find the 30 day evaluation.
I was hoping to find a V4.30A copy of the KickStart package so I had more than 30 days to play with it - does such a thing exist?
Peter
My impression is that it is not time limited, but limited to 32kBytes of download code, which certainly is enough for evaluation.
Jokke
