jwestmoreland wrote on Monday, October 01, 2007:
Brishak,
Try the following - it builds the files for me. If it doesn’t work for you - then I have to conclude you are not following the instructions on http://www.freertos.org/portcygn.html
# FreeRTOS.org V4.5.0 - Copyright (C) 2003-2007 Richard Barry.
# This file is part of the FreeRTOS.org distribution.
# FreeRTOS.org is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# FreeRTOS.org is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with FreeRTOS.org; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 US
A
# A special exception to the GPL can be applied should you wish to distrib
ute
# a combined work that includes FreeRTOS.org, without being obliged to pro
vide
# the source code for any proprietary components. See the licensing secti
on
# of http://www.FreeRTOS.org for full details of how and when the exceptio
n
# can be applied.
# See http://www.FreeRTOS.org for documentation, latest information, licen
se
# and contact details. Please ensure to read the configuration and releva
nt
# port sections of the online documentation.
CC=sdcc
NO_OPT=–nogcse --noinvariant --noinduction --nojtbound --noloopreverse --nolabe
lopt --nooverlay --peep-asm
DEBUG=–debug
CFLAGS=–model-large -I. -I…/Common/include -I…/include -I…/…/Source/include
-DSDCC_CYGNAL $(DEBUG) --less-pedantic --xram-size 8448 --stack-
auto
--no-peep --int-long-reent --float-reent --lib-path c:/sdcc/lib/
large
LFLAGS= --lib-path c:/sdcc/lib/large
DEMO_DIR = …/Common
SOURCE_DIR = …/…/Source
PORT_DIR = …/…/Source/portable/SDCC/Cygnal
SRC =
$(DEMO_DIR)/Full/flash.c
$(DEMO_DIR)/Full/print.c
$(DEMO_DIR)/Minimal/integer.c
$(DEMO_DIR)/Minimal/PollQ.c
$(DEMO_DIR)/Minimal/comtest.c
$(DEMO_DIR)/Full/semtest.c
$(SOURCE_DIR)/tasks.c
$(SOURCE_DIR)/queue.c
$(SOURCE_DIR)/list.c
$(SOURCE_DIR)/portable/MemMang/heap_1.c
$(PORT_DIR)/port.c
ParTest/ParTest.c
serial/serial.c
# Define all object files.
OBJ = $(SRC:.c=.rel)
# THIS VERSION WILL ONLY BUILD FILES THAT HAVE CHANGED, BUT MAY HAVE A DANGEROUS
# COMMAND LINE. IT WORKS FINE UNDER WINDOWS, BUT I HAVE COMMENTED IT OUT IN
# CASE IT CAUSES PROBLEMS ON OTHER SYSTEMS.
main : main.c Makefile …/…/Source/portable/SDCC/Cygnal/portmacro.h $(OBJ)
$(CC) $(CFLAGS) main.c $(OBJ)
%.rel : %.c Makefile …/…/Source/portable/SDCC/Cygnal/portmacro.h
$(CC) -c $(CFLAGS) -o$< $<
# INSTEAD OF THE FOUR LINES ABOVE, THIS VERSION CAN BE USED BUT WILL CAUSE ALL
# FILES TO BUILD EVERY TIME.
# main : main.c Makefile …/…/Source/portable/SDCC/Cygnal/portmacro.h $(OBJ)
# $(CC) $(CFLAGS) main.c $(OBJ)
# %.rel : %.c Makefile …/…/Source/portable/SDCC/Cygnal/portmacro.h
# $(CC) -c $(CFLAGS) $<
# end of makefile
You may have to fix-up the formatting - I didn’t see any way to make an attachment to this post.
Regards,
John
