Having problems running the sample programs. Using Windows XP when I connect the board to the USB it finds new hardware connected , hence the USB port is working , also the red LED flashes, But it never loads the entire problem to flash error appears @ 57%. . The error dialog I get is “No Emulator / board available” lpc1769 is selected and shows up on the bottom of the LPCXpresso.
Hmm. This is a very unusual problem. The issues that normally arise have symptoms of not connecting at all, or connecting but not being able to stop the CPU, but in your case you seem to connect and stop the CPU ok. I will get in touch with the CodeRed people to see if they have come across this before and, if not, I could send another board (although I have not seen this type of error before).
Ok - it is likely that it is not actually programming the flash at all. The percentage shown in the bottom right of the window when you start a debug session is for the whole debug start up process, only one of which is programming the flash, and programming the flash seems to start when the % shows 57%.
Can you provide the output from the IDE’s console when you try to start a debug session please. You can just cut and paste it. It should look something like this:
LPCXpresso Debug Driver v4.0 (Feb 17 2012 17:57:25)
Looked for chip XML file in C:/devtools/nxp/LPCXpresso_4.2.0_264/lpcxpresso/bin/LPC1769.xml
Looked for vendor directory XML file in C:/devtools/nxp/LPCXpresso_4.2.0_264/lpcxpresso/bin/nxp_directory.xml
Found generic directory XML file in C:/devtools/nxp/LPCXpresso_4.2.0_264/lpcxpresso/bin/crt_directory.xml
nSRST assert (if available)
Executing in user flash.
Emu(0): Conn&Reset. DpID: 2BA01477. Info: T1S6RGRIA
SWD Frequency: 3000 KHz. RTCK: False. Vector catch: True.
Packet delay: 0 Poll delay: 0.
NXP: LPC1769 Part ID: 0x26113F37
Connected: was_reset=false. was_stopped=true
v Registered license, download limit of 128K
Writing 75412 bytes to 0000 in Flash (assumed clock: 4.0MHz)
Erased/Wrote page 0-7 with 32768 bytes in 6701msec
Erased/Wrote page 8-15 with 32768 bytes in 6905msec
Erased/Wrote page 16 with 9876 bytes in 1609msec
Flash write Done
Executing in bootloader.
Stopped: Breakpoint #1
That is what will appear in the build output console. There are multiple consoles, but generally only one is shown at a time.
If you look at the window that you pasted that text from, in the top right corner there should be a set of icons (5 on my computer). One of the icons looks like an computer monitor, and has a little arrow by it. If you click the arrow you will see the other consoles, and will be able to select alternatives. Probably the one you want is MCU debug log.
I found the dialog icon box with the arrow on the left , when I click to expand there are only 2 options 1) CVS 2) another dialog session. If I select that it shows the the same output I pasted on top before.
Is it normal for the red LED to flash with the USB port connected?
The only LED on the board is under the control of the application running on the MCU, so, if the board is shipped with test software already installed (probably) then yes it is likely the LED will flash.
My other question was about resetting your computer - did you reset it after installing the software?
