How could I use FreeRTOS RDB1768 Example with LPCXpresso1768+Base board?
I’ve compile and debug it, but when I try to connect to base board from PC, browser said me “Connection timed out”. Does anyone know what should I change in examples?
Do the RDB1768 and LPCXpresso base board use the same network interface and PHY? Are you sure the TCP/IP stack is even initializing the hradware correctly?
Yes, they’ve use the same PHY (LAN8720), and I’ve successfully run RDB1768_Easyweb_CMSIS example on LPCXpresso+baseboard, but FreeRTOS example is non-CMSIS. I don’t have any non-CMSIS examples for LPCXpresso and can’t compare it…
