I have never seen that error, so don’t know what it is or how to reproduce it. Can you tell me which version of LPCXpresso IDE you are using, and I will try and get more information. Thanks.
+ if the user is still having problems, then they should post full details of his setup and issues as a new thread on the forum. I’m sure one of the forum members will then help him out.
If all that fails to rectify the issue, then please get back to me.
well I am using your baseboard and ebook for tutorial purpose to understand FREERtos and its APIs, I am quite new to it, I only have usb connection and when I plug the usb connection the device is detected properly and the red LED 2 lights up. I am not using any hub. I tried every possible way but I could not get any solution even I installed the IDE on brand new computer but I still had the same problem I believe it is the hardware.
Just to clarify, the hardware I sent out is the LPCXpresso board itself. It looks like this (the top part of this image only)
The LPCXpresso board can then fit onto a base board that looks like this
I have only sent the LPCXpresso hardware, so unless you have purchased the base board from elsewhere, you are probably (I’m guessing) not using a base board.
I can send you another LPCXpresso board, but it is unlikely that will solve the problem as I have not had any issues with that revision of board before. There is a first time for everything though. The new board will get sent out tomorrow.
It seems to be working. I went into debug configuration of the programme and changed the vector catch to true from false and applied the setting and then it started working. But I am not sure what exactly happened, what it did to the hardware.
