floppel wrote on Tuesday, February 10, 2009:
Could some one help me?
I am trying to get Free RTOS running on an LPC2109. I am using the Arm 7 LPC2106 GCC code since they are very similar chips.
So far I have:
- Reduced the RAM and Flash in lpc2106.ld
- Modified the heap size in FreeRTOSConfig.h
- Removed all demo programs except flash from both main.c as well as the makefile to shrink the overall image
I am developing on Ubuntu and burning using lpc21isp
I keep getting this error message.
make -k burn
…/build/lpc21isp rtosdemo.ihex /dev/ttyUSB0 115200 14746
File rtosdemo.ihex loaded…
Converting file rtosdemo.ihex to binary format…
File rtosdemo.ihex converted to binary format…
Position 0x14 patched: ivt_CRC = 0xB4C044D3
COM-Port /dev/ttyUSB0 opened…
Synchronizing
Synchronized 0
Synchronized 1
Setting oscillator
Unlock
Read bootcode version
Read part ID
Writing Sector 0: …Wrong answer on Write-Command
make: *** [burn] Error 4
ADDR_NOT_MAPPED: Address is not mapped in the memory map. Count value is taken in to consideration where applicable.
However if i burn it onto a board using the LPC2104 it burns fine.
Does anyone have any suggestions of what I need to do to fix my issue?
Colin
