I have been working on compiling freeRTOS port for my chipset and have run into one problem that doesnt seem to have an answer. When compiling the uipopt.h file the “#include uip-conf.h” is not found and does not exist in my chipsets demo tree. So I am wondering if this is nesesarry to completed the demo and I need to make the file or if I should not be compiling this. For reference I am using freeRTOS v10.2.1 Gcc [arm-altera-eabi] toolchain v6.2.0 and eclipse DS-5 v5.29.1 as well as attempting to follow the steps detailed by freeRTOS to setup. Thank you
Yeah I had seen this and was confused as to why I was getting this error if my board doesnt have a demo for this. Iit seems to be compiling the ethernet files in common should I just remove these from the project?
Can’t really say as I don’t know what it is you are compiling. I don’t
have the tools installed right now so can’t try it myself - can you
explain how you opened the project - did you follow these instructions https://www.freertos.org/RTOS_Altera_SoC_ARM_Cortex-A9.html#build_instructions
? If so, please post a screen shot of the project explorer window in
the IDE with the folders in the tree view expanded.
Unfortunately something seems very broken with the project format as the
screenshot shows all files from all directories being built - that means
it is not only including the uIP code but multiple versions of the lwIP
too so just fixing the uip include file is not going to help.
I’m not sure why this has happened. There should be filters that only
bring in the required files. I suspect the file format for the IDE has
changed.
Went to try and install the tools and also note the link to the tools
download is broken too - maybe everything is on the Intel site now, will
have to do some Googling.
I wonder if that is part of the problem. I’ve just downloaded the tools
from the new link, which is now on the Intel site: http://fpgasoftware.intel.com/soceds/ - you can still select ‘standard’
free edition. It will be a while before I get the chance to try this
though.
