fabtor wrote on Friday, November 03, 2006:
I’ve just finish to port freertos on STR91x using Rowley CrossStudio (GCC).
The RTOS works at 100% with all demonstration tasks but i’ve a problem with uIP.
When i link the ethernet cable, the port seems to initialize correctly , but when i
try to “ping” with my board i don’t receive any reply by it.
I used uIP of the IAR Project and the IP address is setting correctly.
There are particular changes to make for compile uIP under GCC?
Fabrizio
