Executing task: cmake -DVENDOR=st -DBOARD=stm32l4plus_discovery -DCOMPILER=arm-gcc -S . -B build -GNinja
– The C compiler identification is GNU 10.3.1
– The CXX compiler identification is GNU 10.3.1
– The ASM compiler identification is GNU
– Found assembler: /usr/local/bin/arm-none-eabi-gcc
– Found Git: /usr/local/bin/git (found version “2.35.1”)
– Submodule update
=========================Resolving dependencies==========================
module disabled: cellular
reason: cellular::mcu_port is not defined by vendor.
dependency path: demo_base->common->platform->secure_sockets->secure_sockets::mcu_
port->cellular->cellular::mcu_port
CMake Error at tools/cmake/afr_module.cmake:354 (message):
Unable to build aws_demos due to missing dependencies.
Call Stack (most recent call first):
CMakeLists.txt:110 (afr_resolve_dependencies)
– Configuring incomplete, errors occurred!
See also “/Volumes/dataDisk/Users/bruno/STM32/stm32l4plus/build/CMakeFiles/CMakeOutput.log”.
See also “/Volumes/dataDisk/Users/bruno/STM32/stm32l4plus/build/CMakeFiles/CMakeError.log”.
Anybody can point me to the right repository supporting stm32l4plus?
This demo was developed to demonstrate how to use STM32L4plus with cellular interface.
From your error log, It looks like BOARD_HAS_CELLULAR and SECURE_SOCKETS_CELLULAR are not defined in cmake command.
You can give it a try first. I will reply more information later.
