I am trying to make a transition from provided demos to our own source code so we can test how things work with our software. In particular, I have went through Bluetooth OTA Update Example on AWS.
So nowbefore setting up my own project, I decided to try the amazon-freertos example with code from OTA MQTT BLE demo in order to create a starting point for adding other parts related to our code. I have looked through Getting started:Using FreeRTOS in your own CMake project for ESP32 with AWS and also checked some questions on the forum about CMake project setup issues with AWS FreeRTOS for ESP32. I was able to set up my cmake so I start building code, but I have problem when linking some libraries required for ble example, not sure how to add them. Here is my cmake file:
cmake_minimum_required(VERSION 3.13)
project(freertos_examples)
# Tell IDF build to link against this target.
# set(IDF_PROJECT_EXECUTABLE afr_demo)
set(IDF_PROJECT_EXECUTABLE freertos_examples)
set(IDF_EXECUTABLE_SRCS /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/src/main.c)
# Add some extra components. IDF_EXTRA_COMPONENT_DIRS is an variable used by ESP-IDF
# to collect extra components.
# get_filename_component(
# EXTRA_COMPONENT_DIRS
# "components/foo" ABSOLUTE
# list(APPEND IDF_EXTRA_COMPONENT_DIRS ${EXTRA_COMPONENT_DIRS})
# As of now there's no offical way to redefine config files outside of FreeRTOS source tree.
# This is a temporary approach to inject an include path so that this takes precedence over the
# config file directory inside FreeRTOS.
include_directories(BEFORE freertos-configs)
option(AFR_ENABLE_DEMOS "Build demos for FreeRTOS." ON)
# From documentation: idf.py -DVENDOR=espressif -DBOARD=esp32_devkitc -DCOMPILER=xtensa-esp32 build
# add_compile_definitions(COMPILER=xtensa-esp32)
# Add freertos as an subdirectory. AFR_BOARD tells which board to target.
set(AFR_BOARD espressif.esp32_devkitc CACHE INTERNAL "")
add_subdirectory(freertos)
# Link against the mqtt demo so that we can use it. Dependencies of this demo are transitively
# linked.
target_link_libraries(
freertos_examples
PRIVATE
AFR::ble
AFR::ota
# AFR::ota_ble
# AFR::ota::mcu_port
# AFR::dev_mode_key_provisioning
AFR::demo_base
# Add dependency on the ota_demo_dependencies metadata module
# so that FreeRTOS console shows this demo ONLY when the OTA library
# (or another library depending on OTA) is selected on the console.
# AFR::ota_demo_dependencies
idf.py -DCMAKE_TOOLCHAIN_FILE=freertos/tools/cmake/toolchains/xtensa-esp32.cmake build
Executing action: all (aliases: build)
Running ninja in directory /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build
Executing "ninja all"...
[0/2] Re-checking globbed directories...
[1/2] Re-running CMake...
-- Submodule update
Skipping submodule '../../../libraries/abstractions/backoff_algorithm/'
Skipping submodule '../../../../libraries/abstractions/pkcs11/corePKCS11/'
Skipping submodule '../../../libraries/abstractions/pkcs11/corePKCS11/'
Skipping submodule '../../../libraries/coreHTTP/'
Skipping submodule '../../../libraries/coreJSON/'
Skipping submodule '../../../libraries/coreMQTT/'
Skipping submodule '../../../libraries/coreMQTT-Agent/source/dependency/coreMQTT/'
Skipping submodule '../../../libraries/device_defender_for_aws/'
Skipping submodule '../../../libraries/device_shadow_for_aws/'
Skipping submodule '../../libraries/freertos_plus/standard/freertos_plus_tcp/'
Skipping submodule '../../../libraries/jobs_for_aws/'
Skipping submodule '../../../libraries/ota_for_aws/'
Skipping submodule '../../../libraries/ota_for_aws/source/dependency/coreJSON/'
WARNING: IDF_PATH environment variable is not cleared.
If CMake is generating an error, consider clearing the IDF_PATH environment
variable, and generating a clean build. This message can be ignored if
CMake was successful.
-- Component directory /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/mbedtls does not contain a CMakeLists.txt file. No component will be added
-- Component directory /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/unity does not contain a CMakeLists.txt file. No component will be added
-- Checking Python dependencies...
Python requirements from /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/requirements.txt are satisfied.
-- Project sdkconfig file /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig
Loading defaults file /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults...
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:21 CONFIG_NIMBLE_ENABLED was replaced with CONFIG_BT_NIMBLE_ENABLED
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:22 CONFIG_NIMBLE_MAX_CONNECTIONS was replaced with CONFIG_BT_NIMBLE_MAX_CONNECTIONS
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:23 CONFIG_NIMBLE_MAX_BONDS was replaced with CONFIG_BT_NIMBLE_MAX_BONDS
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:24 CONFIG_NIMBLE_MAX_CCCDS was replaced with CONFIG_BT_NIMBLE_MAX_CCCDS
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:25 CONFIG_NIMBLE_L2CAP_COC_MAX_NUM was replaced with CONFIG_BT_NIMBLE_L2CAP_COC_MAX_NUM
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:26 CONFIG_NIMBLE_PINNED_TO_CORE was replaced with CONFIG_BT_NIMBLE_PINNED_TO_CORE
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:27 CONFIG_NIMBLE_ROLE_CENTRAL was replaced with CONFIG_BT_NIMBLE_ROLE_CENTRAL
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:28 CONFIG_NIMBLE_ROLE_PERIPHERAL was replaced with CONFIG_BT_NIMBLE_ROLE_PERIPHERAL
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:29 CONFIG_NIMBLE_ROLE_BROADCASTER was replaced with CONFIG_BT_NIMBLE_ROLE_BROADCASTER
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:30 CONFIG_NIMBLE_ROLE_OBSERVER was replaced with CONFIG_BT_NIMBLE_ROLE_OBSERVER
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:31 CONFIG_NIMBLE_NVS_PERSIST was replaced with CONFIG_BT_NIMBLE_NVS_PERSIST
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:32 CONFIG_NIMBLE_SM_LEGACY was replaced with CONFIG_BT_NIMBLE_SM_LEGACY
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:33 CONFIG_NIMBLE_SM_SC was replaced with CONFIG_BT_NIMBLE_SM_SC
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:34 CONFIG_NIMBLE_DEBUG was replaced with CONFIG_BT_NIMBLE_DEBUG
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:35 CONFIG_NIMBLE_SVC_GAP_DEVICE_NAME was replaced with CONFIG_BT_NIMBLE_SVC_GAP_DEVICE_NAME
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:36 CONFIG_NIMBLE_GAP_DEVICE_NAME_MAX_LEN was replaced with CONFIG_BT_NIMBLE_GAP_DEVICE_NAME_MAX_LEN
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:37 CONFIG_NIMBLE_ATT_PREFERRED_MTU was replaced with CONFIG_BT_NIMBLE_ATT_PREFERRED_MTU
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:38 CONFIG_NIMBLE_SVC_GAP_APPEARANCE was replaced with CONFIG_BT_NIMBLE_SVC_GAP_APPEARANCE
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:39 CONFIG_NIMBLE_ACL_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_ACL_BUF_COUNT
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:40 CONFIG_NIMBLE_ACL_BUF_SIZE was replaced with CONFIG_BT_NIMBLE_ACL_BUF_SIZE
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:41 CONFIG_NIMBLE_HCI_EVT_BUF_SIZE was replaced with CONFIG_BT_NIMBLE_HCI_EVT_BUF_SIZE
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:42 CONFIG_NIMBLE_HCI_EVT_HI_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_HCI_EVT_HI_BUF_COUNT
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:43 CONFIG_NIMBLE_HCI_EVT_LO_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_HCI_EVT_LO_BUF_COUNT
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/sdkconfig.defaults:44 CONFIG_NIMBLE_MESH was replaced with CONFIG_BT_NIMBLE_MESH
/tmp/confgen_tmpymr73lfk:20 line was updated to CONFIG_BT_BLUEDROID_ENABLED=n
/tmp/confgen_tmpymr73lfk:34 line was updated to CONFIG_BT_NIMBLE_DEBUG=n
/tmp/confgen_tmpymr73lfk:44 line was updated to CONFIG_BT_NIMBLE_MESH=n
-- App "freertos_examples" version: 1
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/esp-idf/esp32/esp32_out.ld
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp32/ld/esp32.project.ld.in
-- Adding linker script /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp32/ld/esp32.peripherals.ld
=========================Resolving dependencies==========================
module disabled: posix
reason: posix::mcu_port is not defined by vendor.
dependency path: posix->posix::mcu_port
====================Configuration for FreeRTOS====================
Version: 202107.00
Git version: 202107.00-28-g3416de7b8
Target microcontroller:
vendor: Espressif
board: ESP32-DevKitC
description: Development board produced by Espressif that comes in two
variants either with ESP-WROOM-32 or ESP32-WROVER module
family: ESP32
data ram size: 520KB
program memory size: 4MB
Host platform:
OS: Linux-5.4.0-84-generic
Toolchain: xtensa-esp32
Toolchain path: /home/vasko/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/
xtensa-esp32-elf
CMake generator: Ninja
FreeRTOS modules:
Modules to build: backoff_algorithm, ble, ble_hal, ble_wifi_provisioning,
common, common_io, core_http, core_http_demo_dependencies,
core_json, core_mqtt, core_mqtt_agent, core_mqtt_agent_demo_
dependencies, core_mqtt_demo_dependencies, crypto,
dev_mode_key_provisioning, device_defender, device_defender_
demo_dependencies, device_shadow, device_shadow_demo_
dependencies, freertos_cli_plus_uart, freertos_plus_cli,
greengrass, http_demo_helpers, jobs, jobs_demo_dependencies,
kernel, logging, mqtt_agent_interface, mqtt_demo_helpers,
mqtt_subscription_manager, ota, ota_demo_dependencies,
ota_demo_version, pkcs11, pkcs11_helpers, pkcs11_
implementation, pkcs11_utils, platform, secure_sockets, tls,
transport_interface_secure_sockets, wifi
Enabled by user: ble, ble_hal, ble_wifi_provisioning, common_io, core_http_demo_
dependencies, core_json, core_mqtt_agent_demo_dependencies,
core_mqtt_demo_dependencies, device_defender, device_defender_
greengrass, jobs, jobs_demo_dependencies, logging,
ota_demo_dependencies, pkcs11, pkcs11_helpers, pkcs11_
implementation, pkcs11_utils, platform, secure_sockets, wifi
Enabled by dependency: backoff_algorithm, common, core_http, core_mqtt,
core_mqtt_agent, crypto, demo_base, dev_mode_key_provisioning,
freertos, http_demo_helpers, kernel, mqtt_agent_interface,
mqtt_demo_helpers, mqtt_subscription_manager, ota,
ota_demo_version, pkcs11_mbedtls, tls, transport_interface_
secure_sockets, utils
3rdparty dependencies: jsmn, mbedtls, pkcs11, tinycbor
Available demos: demo_cli_uart, demo_core_http, demo_core_mqtt, demo_core_mqtt_
agent, demo_device_defender, demo_device_shadow,
demo_gatt_server, demo_greengrass_connectivity, demo_jobs,
demo_mqtt_ble, demo_numeric_comparison, demo_ota_ble,
demo_ota_core_http, demo_ota_core_mqtt, demo_shadow_ble,
demo_tcp, demo_wifi_provisioning
Available tests:
-- Configuring done
-- Generating done
-- Build files have been written to: /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build
[12/30] Building C object freertos/CMakeFiles/freertos_examples.dir/__/src/main.c.obj
../src/main.c: In function 'prvMiscInitialization':
../src/main.c:173:13: warning: unused variable 'uartRet' [-Wunused-variable]
int32_t uartRet;
../src/main.c: In function 'xPortGetUserInput':
../src/main.c:289:20: warning: unused variable 'xReturnMessage' [-Wunused-variable]
BaseType_t xReturnMessage = pdFALSE;
[17/30] Performing build step for 'bootloader'
ninja: no work to do.
[23/28] Building C object freertos/CMakeFiles/freertos_examples.dir/demos/network_manager/aws_iot_network_manager.c.obj
../freertos/demos/network_manager/aws_iot_network_manager.c:277:31: warning: 'tcpIPConnectionParams' defined but not used [-Wunused-variable]
static IotNetworkServerInfo_t tcpIPConnectionParams = { 0 };
../freertos/demos/network_manager/aws_iot_network_manager.c:272:32: warning: 'tcpIPCredentials' defined but not used [-Wunused-variable]
static IotNetworkCredentials_t tcpIPCredentials = { 0 };
[24/28] Building C object freertos/CMakeFiles/freertos_example...r/vendors/espressif/boards/ports/ota_pal_for_aws/ota_pal.c.obj
../freertos/vendors/espressif/boards/ports/ota_pal_for_aws/ota_pal.c:80:21: warning: 'TAG' defined but not used [-Wunused-variable]
static const char * TAG = "ota_pal";
[27/28] Linking CXX executable freertos_examples
FAILED: freertos_examples
: && /home/vasko/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++ -mlongcalls -Wl,--gc-sections -Wl,--cref -Wl,--Map=freertos_examples.map -Wl,--undefined=uxTopUsedPriority freertos/CMakeFiles/freertos_examples.dir/__/src/main.c.obj freertos/CMakeFiles/freertos_examples.dir/libraries/freertos_plus/standard/utils/src/iot_system_init.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp_bignum.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp_mem.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp_hardware.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/mbedtls_debug.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp_aes_xts.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp_sha.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp_timing.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/net_sockets.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/aes.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/sha.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/esp_sha1.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/esp_sha512.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/esp_sha256.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/boards/ports/common_io/iot_i2c.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/boards/ports/common_io/iot_spi.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/boards/ports/common_io/iot_uart.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/boards/ports/ota_pal_for_aws/ota_pal.c.obj freertos/CMakeFiles/freertos_examples.dir/vendors/espressif/boards/ports/ota_pal_for_aws/aws_esp_ota_ops.c.obj freertos/CMakeFiles/freertos_examples.dir/demos/demo_runner/aws_demo.c.obj freertos/CMakeFiles/freertos_examples.dir/demos/network_manager/aws_iot_network_manager.c.obj freertos/CMakeFiles/freertos_examples.dir/demos/demo_runner/iot_demo_freertos.c.obj freertos/CMakeFiles/freertos_examples.dir/demos/demo_runner/iot_demo_runner.c.obj -o freertos_examples freertos/afr_wifi.a freertos/afr_ble.a freertos/afr_common_io.a -fno-rtti -fno-lto freertos/afr_ble.a freertos/afr_ota.a freertos/afr_ota.a freertos/afr_core_json.a freertos/afr_dev_mode_key_provisioning.a freertos/afr_ble_wifi_provisioning.a freertos/afr_wifi.a freertos/afr_secure_sockets.a freertos/afr_tls.a freertos/afr_wifi.a freertos/afr_secure_sockets.a freertos/afr_tls.a freertos/afr_pkcs11_implementation.a freertos/afr_pkcs11.a freertos/afr_pkcs11_implementation.a freertos/afr_pkcs11.a freertos/afr_pkcs11_utils.a freertos/afr_crypto.a freertos/afr_ble.a freertos/afr_ble_hal.a freertos/afr_ble.a freertos/afr_ble_hal.a freertos/afr_platform.a freertos/afr_logging.a freertos/afr_common.a freertos/afr_platform.a freertos/afr_logging.a freertos/afr_common.a esp-idf/bt/libbt.a esp-idf/cxx/libcxx.a esp-idf/newlib/libnewlib.a esp-idf/freertos/libfreertos.a esp-idf/heap/libheap.a esp-idf/log/liblog.a esp-idf/lwip/liblwip.a esp-idf/soc/libsoc.a esp-idf/esp_common/libesp_common.a esp-idf/esp_system/libesp_system.a esp-idf/xtensa/libxtensa.a esp-idf/esp32/libesp32.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/pthread/libpthread.a esp-idf/app_trace/libapp_trace.a esp-idf/vfs/libvfs.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_netif/libesp_netif.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/soc/soc/esp32/libsoc_esp32.a esp-idf/espcoredump/libespcoredump.a esp-idf/ulp/libulp.a esp-idf/efuse/libefuse.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/spi_flash/libspi_flash.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/driver/libdriver.a esp-idf/perfmon/libperfmon.a esp-idf/esp_event/libesp_event.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libcore.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libespnow.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libmesh.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libpp.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/librtc.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libphy.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/cxx/libcxx.a esp-idf/newlib/libnewlib.a esp-idf/freertos/libfreertos.a esp-idf/heap/libheap.a esp-idf/log/liblog.a esp-idf/lwip/liblwip.a esp-idf/soc/libsoc.a esp-idf/esp_common/libesp_common.a esp-idf/esp_system/libesp_system.a esp-idf/xtensa/libxtensa.a esp-idf/esp32/libesp32.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/pthread/libpthread.a esp-idf/app_trace/libapp_trace.a esp-idf/vfs/libvfs.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_netif/libesp_netif.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/soc/soc/esp32/libsoc_esp32.a esp-idf/espcoredump/libespcoredump.a esp-idf/ulp/libulp.a esp-idf/efuse/libefuse.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/spi_flash/libspi_flash.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/driver/libdriver.a esp-idf/perfmon/libperfmon.a esp-idf/esp_event/libesp_event.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libcore.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libespnow.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libmesh.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libpp.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/librtc.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libphy.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/cxx/libcxx.a esp-idf/newlib/libnewlib.a esp-idf/freertos/libfreertos.a esp-idf/heap/libheap.a esp-idf/log/liblog.a esp-idf/lwip/liblwip.a esp-idf/soc/libsoc.a esp-idf/esp_common/libesp_common.a esp-idf/esp_system/libesp_system.a esp-idf/xtensa/libxtensa.a esp-idf/esp32/libesp32.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/pthread/libpthread.a esp-idf/app_trace/libapp_trace.a esp-idf/vfs/libvfs.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_netif/libesp_netif.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/soc/soc/esp32/libsoc_esp32.a esp-idf/espcoredump/libespcoredump.a esp-idf/ulp/libulp.a esp-idf/efuse/libefuse.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/spi_flash/libspi_flash.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/driver/libdriver.a esp-idf/perfmon/libperfmon.a esp-idf/esp_event/libesp_event.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libcore.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libespnow.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libmesh.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libpp.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/librtc.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libphy.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/cxx/libcxx.a esp-idf/newlib/libnewlib.a esp-idf/freertos/libfreertos.a esp-idf/heap/libheap.a esp-idf/log/liblog.a esp-idf/lwip/liblwip.a esp-idf/soc/libsoc.a esp-idf/esp_common/libesp_common.a esp-idf/esp_system/libesp_system.a esp-idf/xtensa/libxtensa.a esp-idf/esp32/libesp32.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_timer/libesp_timer.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/pthread/libpthread.a esp-idf/app_trace/libapp_trace.a esp-idf/vfs/libvfs.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/esp_eth/libesp_eth.a esp-idf/esp_netif/libesp_netif.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/soc/soc/esp32/libsoc_esp32.a esp-idf/espcoredump/libespcoredump.a esp-idf/ulp/libulp.a esp-idf/efuse/libefuse.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/spi_flash/libspi_flash.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/driver/libdriver.a esp-idf/perfmon/libperfmon.a esp-idf/esp_event/libesp_event.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libcore.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libespnow.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libmesh.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libpp.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/librtc.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a ../freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32/libphy.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_ringbuf/libesp_ringbuf.a -u __cxa_guard_dummy -lstdc++ esp-idf/pthread/libpthread.a -u __cxx_fatal_exception -lm esp-idf/newlib/libnewlib.a -u newlib_include_locks_impl -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -L /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld -T esp32.rom.newlib-time.ld -T esp32.rom.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.rom.newlib-funcs.ld -Wl,--gc-sections ../freertos/vendors/espressif/esp-idf/components/xtensa/esp32/libhal.a -lgcc -L /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/esp-idf/esp32 -T esp32_out.ld -u app_main -L /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/esp-idf/esp32/ld -T esp32.project.ld -L /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp32/ld -T esp32.peripherals.ld -u call_user_start_cpu0 -u ld_include_panic_highint_hdl -Wl,--wrap=vPortCleanUpTCB -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl esp-idf/app_trace/libapp_trace.a -lgcov esp-idf/app_trace/libapp_trace.a -lgcov -lc -u vfs_include_syscalls_impl -L /home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/esp_wifi/lib/esp32 -u esp_app_desc freertos/libraries/3rdparty/libafr_3rdparty_mbedtls.a -L/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/freertos/vendors/espressif/esp-idf/components/bt/controller/lib -lbtdm_app freertos/afr_kernel.a freertos/libraries/3rdparty/libafr_3rdparty_tinycbor.a && :
/home/vasko/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: freertos/CMakeFiles/freertos_examples.dir/demos/network_manager/aws_iot_network_manager.c.obj:(.literal._bleRegisterUnregisterCb+0x4): undefined reference to `vDemoBLEGAPPairingStateChangedCb'
/home/vasko/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: freertos/CMakeFiles/freertos_examples.dir/demos/network_manager/aws_iot_network_manager.c.obj:(.literal._bleRegisterUnregisterCb+0x8): undefined reference to `vDemoBLENumericComparisonCb'
/home/vasko/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: freertos/CMakeFiles/freertos_examples.dir/demos/network_manager/aws_iot_network_manager.c.obj:(.literal.AwsIotNetworkManager_EnableNetwork+0x10): undefined reference to `vDemoBLENumericComparisonInit'
/home/vasko/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: freertos/CMakeFiles/freertos_examples.dir/demos/network_manager/aws_iot_network_manager.c.obj: in function `_bleEnable':
/home/vasko/embd/esp32/amazon-template-examples/amazon-freertos-examples/build/../freertos/demos/network_manager/aws_iot_network_manager.c:393: undefined reference to `vDemoBLENumericComparisonInit'
/home/vasko/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: freertos/CMakeFiles/freertos_examples.dir/demos/demo_runner/iot_demo_runner.c.obj:(.data.mqttDemoContext$5226+0x4): undefined reference to `RunOtaMqttBLETransportDemo'
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
ninja failed with exit code 1
