I am trying to connect my ST B-L475E-IoT01A kit to AWS by following steps as mentioned in AWS resources. All the required credentials ware entered and downloaded the zip file. I am using AC6 workbench to compile the downloaded file.
I get following error while attempting to build the project :
make: *** [vendors/st/stm32l475_discovery/STM32L4xx_HAL_Driver/stm32l4xx_hal.o] Error 1aws_demos C/C++ Problem
recipe for target ‘vendors/st/stm32l475_discovery/STM32L4xx_HAL_Driver/stm32l4xx_hal.o’ failed subdir.mk /aws_demos/Debug/vendors/st/stm32l475_discovery/STM32L4xx_HAL_Driver line 84 C/C++ Problem
Please guide on how do I solve this error
Regards
Pkvasan
Did you use Quick Connect workflow? Which AWS region are you using?
I tried both “Quick Connect” and “Download from Amazon FreeRTOS Console” for STM32L4 and it builds successfully for me. Would you be able to share the source code zip you got so that we can take a look why is it failing?
Edited by: Gaurav-Aggarwal-AWS on Sep 5, 2019 12:19 PM
Thanks for your response,
yes, I used Quick Connect workflow, using US-west-2 region.
I am not that familiar in using AC6, not able to understand what this error about?
I get this error :
it points to this file -->subdir.mk at line no 84
Please help
