I was successfully able to build and run the AWS demos (MQTT, OTA, BLE) but unable to build the custom project example using Freertos for both methods (with components and without components). The complete details are mentioned below. I would like to know how to resolve this issue or what could be wrong. If further information is required, please let me know.
Target microcontroller: vendor: Espressif
board: ESP32-DevKitC
Host platform: OS: Ubuntu 18.04.5 LTS
Toolchain: xtensa-esp32
Toolchain path: /home/user/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf
CMake generator: Ninja
AWS Freertos version: 202107.00
Followed the steps as mentioned in the AWS User guide
Method 1:
For project directory structure
freertos (the copy that you obtained from GitHub or the AWS IoT console)
src - > main.c (application code)
CMakeLists.txt
After executing the command: cmake -S . -B build -DCMAKE_TOOLCHAIN_FILE=freertos/tools/cmake/toolchains/xtensa-esp32.cmake -GNinja
The error obtained is as below
-- The C compiler identification is GNU 5.2.0
-- The CXX compiler identification is GNU 5.2.0
-- The ASM compiler identification is GNU
-- Found assembler: /home/augmented/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
-- Found Git: /usr/bin/git (found version "2.17.1")
CMake Warning at freertos/vendors/espressif/esp-idf/tools/cmake/idf.cmake:24 (message):
IDF_PATH environment variable not found. Setting IDF_PATH to
'/home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf'.
Call Stack (most recent call first):
freertos/vendors/espressif/boards/esp32/CMakeLists.txt:38 (include)
freertos/CMakeLists.txt:70 (include)
-- Component directory /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/mbedtls does not contain a CMakeLists.txt file. No component will be added
-- Component directory /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/unity does not contain a CMakeLists.txt file. No component will be added
CMake Error at build/freertos/CMakeFiles/git-data/grabRef.cmake:48 (file):
file failed to open for reading (No such file or directory):
/home/augmented/aws_ota/aws_support/build/freertos/CMakeFiles/git-data/head-ref
freertos/vendors/espressif/esp-idf/tools/cmake/third_party/GetGitRevisionDescription.cmake:80 (include)
freertos/vendors/espressif/esp-idf/tools/cmake/third_party/GetGitRevisionDescription.cmake:90 (get_git_head_revision)
freertos/vendors/espressif/esp-idf/tools/cmake/build.cmake:68 (git_describe)
freertos/vendors/espressif/esp-idf/tools/cmake/build.cmake:160 (__build_get_idf_git_revision)
freertos/vendors/espressif/esp-idf/tools/cmake/idf.cmake:49 (__build_init)
CMake Error at freertos/vendors/espressif/boards/esp32/CMakeLists.txt:477 (add_executable):
add_executable cannot create target "my_app" because another target with
the same name already exists. The existing target is an executable created
in source directory "/home/augmented/aws_ota/aws_support". See
documentation for policy CMP0002 for more details.
-- Checking Python dependencies...
Python requirements from /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/requirements.txt are satisfied.
-- Project sdkconfig file /home/augmented/aws_ota/aws_support/build/sdkconfig
Loading defaults file /home/augmented/aws_ota/aws_support/build/sdkconfig.defaults...
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:21 CONFIG_NIMBLE_ENABLED was replaced with CONFIG_BT_NIMBLE_ENABLED
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:22 CONFIG_NIMBLE_MAX_CONNECTIONS was replaced with CONFIG_BT_NIMBLE_MAX_CONNECTIONS
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:23 CONFIG_NIMBLE_MAX_BONDS was replaced with CONFIG_BT_NIMBLE_MAX_BONDS
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:24 CONFIG_NIMBLE_MAX_CCCDS was replaced with CONFIG_BT_NIMBLE_MAX_CCCDS
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:25 CONFIG_NIMBLE_L2CAP_COC_MAX_NUM was replaced with CONFIG_BT_NIMBLE_L2CAP_COC_MAX_NUM
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:26 CONFIG_NIMBLE_PINNED_TO_CORE was replaced with CONFIG_BT_NIMBLE_PINNED_TO_CORE
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:27 CONFIG_NIMBLE_ROLE_CENTRAL was replaced with CONFIG_BT_NIMBLE_ROLE_CENTRAL
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:28 CONFIG_NIMBLE_ROLE_PERIPHERAL was replaced with CONFIG_BT_NIMBLE_ROLE_PERIPHERAL
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:29 CONFIG_NIMBLE_ROLE_BROADCASTER was replaced with CONFIG_BT_NIMBLE_ROLE_BROADCASTER
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:30 CONFIG_NIMBLE_ROLE_OBSERVER was replaced with CONFIG_BT_NIMBLE_ROLE_OBSERVER
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:31 CONFIG_NIMBLE_NVS_PERSIST was replaced with CONFIG_BT_NIMBLE_NVS_PERSIST
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:32 CONFIG_NIMBLE_SM_LEGACY was replaced with CONFIG_BT_NIMBLE_SM_LEGACY
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:33 CONFIG_NIMBLE_SM_SC was replaced with CONFIG_BT_NIMBLE_SM_SC
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:34 CONFIG_NIMBLE_DEBUG was replaced with CONFIG_BT_NIMBLE_DEBUG
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:35 CONFIG_NIMBLE_SVC_GAP_DEVICE_NAME was replaced with CONFIG_BT_NIMBLE_SVC_GAP_DEVICE_NAME
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:36 CONFIG_NIMBLE_GAP_DEVICE_NAME_MAX_LEN was replaced with CONFIG_BT_NIMBLE_GAP_DEVICE_NAME_MAX_LEN
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:37 CONFIG_NIMBLE_ATT_PREFERRED_MTU was replaced with CONFIG_BT_NIMBLE_ATT_PREFERRED_MTU
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:38 CONFIG_NIMBLE_SVC_GAP_APPEARANCE was replaced with CONFIG_BT_NIMBLE_SVC_GAP_APPEARANCE
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:39 CONFIG_NIMBLE_ACL_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_ACL_BUF_COUNT
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:40 CONFIG_NIMBLE_ACL_BUF_SIZE was replaced with CONFIG_BT_NIMBLE_ACL_BUF_SIZE
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:41 CONFIG_NIMBLE_HCI_EVT_BUF_SIZE was replaced with CONFIG_BT_NIMBLE_HCI_EVT_BUF_SIZE
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:42 CONFIG_NIMBLE_HCI_EVT_HI_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_HCI_EVT_HI_BUF_COUNT
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:43 CONFIG_NIMBLE_HCI_EVT_LO_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_HCI_EVT_LO_BUF_COUNT
/home/augmented/aws_ota/aws_support/build/sdkconfig.defaults:44 CONFIG_NIMBLE_MESH was replaced with CONFIG_BT_NIMBLE_MESH
/tmp/confgen_tmpnz5054sg:20 line was updated to CONFIG_BT_BLUEDROID_ENABLED=n
/tmp/confgen_tmpnz5054sg:34 line was updated to CONFIG_BT_NIMBLE_DEBUG=n
/tmp/confgen_tmpnz5054sg:44 line was updated to CONFIG_BT_NIMBLE_MESH=n
CMake Warning at freertos/vendors/espressif/esp-idf/tools/cmake/crosstool_version_check.cmake:8 (message):
Xtensa toolchain
/home/augmented/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc version 5.2.0
is not the supported version 8.4.0. Check Getting Started documentation or
proceed at own risk.
freertos/vendors/espressif/esp-idf/components/esp32/project_include.cmake:30 (gcc_version_check)
freertos/vendors/espressif/esp-idf/tools/cmake/build.cmake:306 (include)
freertos/vendors/espressif/esp-idf/tools/cmake/build.cmake:451 (__build_process_project_includes)
freertos/vendors/espressif/boards/esp32/CMakeLists.txt:600 (idf_build_process)
CMake Warning at freertos/vendors/espressif/esp-idf/tools/cmake/crosstool_version_check.cmake:28 (message):
Xtensa toolchain
/home/augmented/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc crosstool-ng
version crosstool-ng-1.22.0-80-g6c4433a doesn't match supported version
esp-2020r3. Check Getting Started documentation or proceed at own risk.
freertos/vendors/espressif/esp-idf/components/esp32/project_include.cmake:31 (crosstool_version_check)
-- App "aws_support" version: 1
-- Adding linker script /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld
-- Adding linker script /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script /home/augmented/aws_ota/aws_support/build/esp-idf/esp32/esp32_out.ld
-- Adding linker script /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/esp32/ld/esp32.project.ld.in
-- Adding linker script /home/augmented/aws_ota/aws_support/freertos/vendors/espressif/esp-idf/components/esp32/ld/esp32.peripherals.ld
=========================Resolving dependencies==========================
All modules available
====================Configuration for FreeRTOS====================
Version: 202107.00
Git version: Unknown
vendor: Espressif
description: Development board produced by Espressif that comes in two
variants either with ESP-WROOM-32 or ESP32-WROVER module
family: ESP32
data ram size: 520KB
program memory size: 4MB
Host platform:
OS: Linux-5.4.0-80-generic
Toolchain path: /home/augmented/esp/xtensa-esp32-elf
FreeRTOS modules:
Modules to build: backoff_algorithm, ble, ble_hal, ble_wifi_provisioning,
common, common_io, core_http, core_http_demo_dependencies,
core_json, core_mqtt, core_mqtt_agent, core_mqtt_agent_demo_
dependencies, core_mqtt_demo_dependencies, crypto,
dev_mode_key_provisioning, http_demo_helpers, jobs,
jobs_demo_dependencies, kernel, logging, mqtt_agent_interface,
mqtt_demo_helpers, mqtt_subscription_manager, ota,
ota_demo_dependencies, ota_demo_version, pkcs11,
pkcs11_helpers, pkcs11_implementation, pkcs11_utils, platform,
secure_sockets, tls, transport_interface_secure_sockets, wifi
Enabled by user: ble, ble_hal, ble_wifi_provisioning, common_io, core_http_demo_
dependencies, core_json, core_mqtt_agent_demo_dependencies,
core_mqtt_demo_dependencies, jobs, jobs_demo_dependencies,
logging, ota_demo_dependencies, pkcs11, pkcs11_helpers,
pkcs11_implementation, pkcs11_utils, platform, secure_sockets,
wifi
Enabled by dependency: backoff_algorithm, common, core_http, core_mqtt,
core_mqtt_agent, crypto, demo_base, dev_mode_key_provisioning,
freertos, http_demo_helpers, kernel, mqtt_agent_interface,
ota_demo_version, pkcs11_mbedtls, tls, transport_interface_
secure_sockets, utils
3rdparty dependencies: mbedtls, pkcs11, tinycbor
Available demos: demo_core_http, demo_core_mqtt, demo_core_mqtt_agent,
demo_gatt_server, demo_jobs, demo_mqtt_ble, demo_numeric_
comparison, demo_ota_ble, demo_ota_core_http, demo_ota_core_
mqtt, demo_tcp, demo_wifi_provisioning
Available tests:
-- Configuring incomplete, errors occurred!
See also "/home/augmented/aws_ota/aws_support/build/CMakeFiles/CMakeOutput.log".
See also "/home/augmented/aws_ota/aws_support/build/CMakeFiles/CMakeError.log".
Method 2:
For project directory structure (Used the exact example from the github repository on the branch shubhamkulkarni97/amazon-freertos-examples)
freertos
components
example_component
include
- example_component.h
src
- example_component.c
CMakeLists.txt
src
- main.c
CMakeLists.txt
'/home/augmented/aws_support/freertos/vendors/espressif/esp-idf'.
CMakeLists.txt:6 (include)
-- Component directory /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/mbedtls does not contain a CMakeLists.txt file. No component will be added
-- Component directory /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/unity does not contain a CMakeLists.txt file. No component will be added
CMake Error at build/CMakeFiles/git-data/grabRef.cmake:48 (file):
/home/augmented/aws_support/build/CMakeFiles/git-data/head-ref
WARNING: IDF_PATH environment variable is not cleared.
If CMake is generating an error, consider clearing the IDF_PATH environment
variable, and generating a clean build. This message can be ignored if
CMake was successful.
Python requirements from /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/requirements.txt are satisfied.
-- Project sdkconfig file /home/augmented/aws_support/build/sdkconfig
Loading defaults file /home/augmented/aws_support/build/sdkconfig.defaults...
/home/augmented/aws_support/build/sdkconfig.defaults:21 CONFIG_NIMBLE_ENABLED was replaced with CONFIG_BT_NIMBLE_ENABLED
/home/augmented/aws_support/build/sdkconfig.defaults:22 CONFIG_NIMBLE_MAX_CONNECTIONS was replaced with CONFIG_BT_NIMBLE_MAX_CONNECTIONS
/home/augmented/aws_support/build/sdkconfig.defaults:23 CONFIG_NIMBLE_MAX_BONDS was replaced with CONFIG_BT_NIMBLE_MAX_BONDS
/home/augmented/aws_support/build/sdkconfig.defaults:24 CONFIG_NIMBLE_MAX_CCCDS was replaced with CONFIG_BT_NIMBLE_MAX_CCCDS
/home/augmented/aws_support/build/sdkconfig.defaults:25 CONFIG_NIMBLE_L2CAP_COC_MAX_NUM was replaced with CONFIG_BT_NIMBLE_L2CAP_COC_MAX_NUM
/home/augmented/aws_support/build/sdkconfig.defaults:26 CONFIG_NIMBLE_PINNED_TO_CORE was replaced with CONFIG_BT_NIMBLE_PINNED_TO_CORE
/home/augmented/aws_support/build/sdkconfig.defaults:27 CONFIG_NIMBLE_ROLE_CENTRAL was replaced with CONFIG_BT_NIMBLE_ROLE_CENTRAL
/home/augmented/aws_support/build/sdkconfig.defaults:28 CONFIG_NIMBLE_ROLE_PERIPHERAL was replaced with CONFIG_BT_NIMBLE_ROLE_PERIPHERAL
/home/augmented/aws_support/build/sdkconfig.defaults:29 CONFIG_NIMBLE_ROLE_BROADCASTER was replaced with CONFIG_BT_NIMBLE_ROLE_BROADCASTER
/home/augmented/aws_support/build/sdkconfig.defaults:30 CONFIG_NIMBLE_ROLE_OBSERVER was replaced with CONFIG_BT_NIMBLE_ROLE_OBSERVER
/home/augmented/aws_support/build/sdkconfig.defaults:31 CONFIG_NIMBLE_NVS_PERSIST was replaced with CONFIG_BT_NIMBLE_NVS_PERSIST
/home/augmented/aws_support/build/sdkconfig.defaults:32 CONFIG_NIMBLE_SM_LEGACY was replaced with CONFIG_BT_NIMBLE_SM_LEGACY
/home/augmented/aws_support/build/sdkconfig.defaults:33 CONFIG_NIMBLE_SM_SC was replaced with CONFIG_BT_NIMBLE_SM_SC
/home/augmented/aws_support/build/sdkconfig.defaults:34 CONFIG_NIMBLE_DEBUG was replaced with CONFIG_BT_NIMBLE_DEBUG
/home/augmented/aws_support/build/sdkconfig.defaults:35 CONFIG_NIMBLE_SVC_GAP_DEVICE_NAME was replaced with CONFIG_BT_NIMBLE_SVC_GAP_DEVICE_NAME
/home/augmented/aws_support/build/sdkconfig.defaults:36 CONFIG_NIMBLE_GAP_DEVICE_NAME_MAX_LEN was replaced with CONFIG_BT_NIMBLE_GAP_DEVICE_NAME_MAX_LEN
/home/augmented/aws_support/build/sdkconfig.defaults:37 CONFIG_NIMBLE_ATT_PREFERRED_MTU was replaced with CONFIG_BT_NIMBLE_ATT_PREFERRED_MTU
/home/augmented/aws_support/build/sdkconfig.defaults:38 CONFIG_NIMBLE_SVC_GAP_APPEARANCE was replaced with CONFIG_BT_NIMBLE_SVC_GAP_APPEARANCE
/home/augmented/aws_support/build/sdkconfig.defaults:39 CONFIG_NIMBLE_ACL_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_ACL_BUF_COUNT
/home/augmented/aws_support/build/sdkconfig.defaults:40 CONFIG_NIMBLE_ACL_BUF_SIZE was replaced with CONFIG_BT_NIMBLE_ACL_BUF_SIZE
/home/augmented/aws_support/build/sdkconfig.defaults:41 CONFIG_NIMBLE_HCI_EVT_BUF_SIZE was replaced with CONFIG_BT_NIMBLE_HCI_EVT_BUF_SIZE
/home/augmented/aws_support/build/sdkconfig.defaults:42 CONFIG_NIMBLE_HCI_EVT_HI_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_HCI_EVT_HI_BUF_COUNT
/home/augmented/aws_support/build/sdkconfig.defaults:43 CONFIG_NIMBLE_HCI_EVT_LO_BUF_COUNT was replaced with CONFIG_BT_NIMBLE_HCI_EVT_LO_BUF_COUNT
/home/augmented/aws_support/build/sdkconfig.defaults:44 CONFIG_NIMBLE_MESH was replaced with CONFIG_BT_NIMBLE_MESH
/tmp/confgen_tmpxp_ahs3x:20 line was updated to CONFIG_BT_BLUEDROID_ENABLED=n
/tmp/confgen_tmpxp_ahs3x:34 line was updated to CONFIG_BT_NIMBLE_DEBUG=n
/tmp/confgen_tmpxp_ahs3x:44 line was updated to CONFIG_BT_NIMBLE_MESH=n
-- App "freertos_examples" version: 1
-- Adding linker script /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld
-- Adding linker script /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script /home/augmented/aws_support/build/esp-idf/esp32/esp32_out.ld
-- Adding linker script /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/esp32/ld/esp32.project.ld.in
-- Adding linker script /home/augmented/aws_support/freertos/vendors/espressif/esp-idf/components/esp32/ld/esp32.peripherals.ld
CMake Error at components/foo/CMakeLists.txt:6 (target_link_libraries):
INTERFACE library can only be used with the INTERFACE keyword of
Version: 202107.00
vendor: Espressif
family: ESP32
Host platform:
Toolchain path: /home/augmented/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.
FreeRTOS modules:
wifi
Available tests:
See also "/home/augmented/aws_support/build/CMakeFiles/CMakeOutput.log".
