In FreeRTOS RISC-V trap handler (freertos_risc_v_trap_handler) function, it seems to switch to ISR stack without checking interrupt level, which will get problem if nested interrupt happens.
Does FreeRTOS RISC-V port support nested interrupt?
At this time the port does not implement interrupt nesting, although the
port is under active development and we plan to add interrupt nesting at
a later date, especially where the code is executed on larger devices.
I am searching nested interrupt support for RISC-V and find this old post. I read the latest RISC-V port code, it looks not support nested interrupt so far (July 2022). If that is right, do you have a plan for implementing this feature ? I am learning RISC-V and hope I can help with this if needed.
Hello @HONGWANG! Thanks for reaching out. The previous update by Richard still stands. The port is active development and we plan on adding interrupt nesting in the future.
We welcome all help! The code is open source, so if you’re able to implement a feature you’d like to see please cut a pull request.
