ayazar wrote on Wednesday, November 01, 2017:
I am experimenting with FreeRTOS v9.0.0 on Zynq by expanding the example project. There are 3 interrupt sources and they are async. to each other, for example one interrupt is from serial port receive action and another one is generated from an input pin which occurs independently from serial channel. I also log during runtime on RAM using trace provided by FreeRTOS and analyze the results using free edition of Tracealyzer. At the beginning, I assigned different priorites to each interrupt. These priorites were appropriate such that I was able to call …FromISR() functions inside ISRs. However the code showed up problems when it ran about 5 minutes. At some point, in order to debug problem I assigned same priorites to all interrupts. Then, I did lots of change and since it is a learning project for me I didn’t use version control (!).
Now, the code runs more than 24 hours without any problem but I realized that if I configure interrupts with different priorites as in before, I get different ARM exceptions (sometimes “undefined”, somtimes “data abort” and some times “prefetch abort”). I verify that problem occurs when an interrupt is nested with another one by looking trace logs with Tracealyzer.
I know that this is an general question and it may not be related with FreeRTOS directly but I want to hear suggestions if any. Can there be any misusage of FreeRTOS API functions such that there is a problem only a nested interrupt is occured? As I said, code works well if I don’t use nested interrupts. Additionaly, there is no shared data between ISR functions. I am not very familiar with FreeRTOS internals and ARM itself so I can’t comment by thinking what FreeRTOS does when a nested interrupt occurs. In interrupts, I either send a message to a queue or give a semaphore. Enabling/disabling trace functions on the code doesn’t change the result.
I would appreciate any ideas.
Best,
Alper
