nobody wrote on Tuesday, November 07, 2006:
Im using the Keil MCB-STR9 evaluation board with keil compiler. Do you have an existing freertos port for this board?
rtel wrote on Tuesday, November 07, 2006:
I only have a demo for the ST board. You should be able to convert the existing demo to run on this board fairly easily. I don’t know if they share the same PHY component, this could be an area to watch.
Using the new compiler shipped with the Keil tools would require more effort. I have an example for a different processor sent by a third party that I could send you to get started with but I expect it would be a few days work.
zmax444 wrote on Wednesday, July 18, 2007:
And now do author have freertos port for this board?
