kg4ysn wrote on Monday, September 15, 2008:
Hey all,
We are starting to build a system around FreeRTOS, and I wanted to verify my dev environment before really getting into the nitty gritty coding. I wrote a simple program that was supposed to only have an Idle task:
#include <plib.h>
#include "FreeRTOS.h"
#include "task.h"
int main(void)
vTaskStartScheduler();
return 0;
void vApplicationStackOverflowHook(void)
/* Run for the hills */
I loaded this up in MPLAB IDE v8.10 and got it to compile fine using C32 v1.0.3. When I loaded the MPLAB SIM debugger and run the program, I get the following errors:
CORE-W0018: Instruction at 0x9fc0120c decoded as Reserved (NOP)
CORE-W0018: Instruction at 0x9fc01210 decoded as Reserved (NOP)
CORE-W0018: Instruction at 0x9fc01214 decoded as Reserved (NOP)
MAXIMUM number of warnings/errors exceeded 200, program execution halted.
I tried to step through the code and have deduced that vTaskStartScheduler() fires off properly and the Idle task runs for awhile. Somewhere around the time a context switch takes place (in the ISR_Support.h file), these errors begin to pop up.
Any ideas?
Thanks,
Chris
