I am trying to compile the WEBSERVER project for LPC2368 under eclipse and it give me the following warning
Invalid project path: Include path not found (C:\devtools\codesourcery\sourcery g++ lite\arm-none-eabi\include).
Invalid project path: Include path not found (C:\devtools\codesourcery\sourcery g++ lite\lib\gcc\arm-none-eabi\4.2.0\include-fixed).
Invalid project path: Include path not found (C:\devtools\yagarto\lib\gcc\arm-elf\4.1.1\include)
I am sure how I can resolve this, I would appreciate if you could provide so help
It looks like the absoulte path to header files has been included in the project somehow.
Try running a clean from the project menu to see if the include paths are regenerated. if this does not work then go into the project properties, under C/C++ general in the left frame of the properties window select paths and symbols, and edit the include paths to be correct for your computer.
I have try to run clean and I went to C/C++ general but the <EDIT> button is disabled. I have create the exact directory that it looks for, and it seem to work. But I still miss "sourcery g++ lite" would you know where I can get it.
Also how can I generate a HEX file so that I can download it through the flash utility tool from NXP.
