Compiling ARM7_LPC2368_Eclipse demo
sergiosider wrote on Monday, March 02, 2009:
Hi guys,
I am getting erros when I tried to compile the ARM7_LPC2368_Eclipse demo using
arm-none-eabi (from Codesourcery).
They appear to be "linker" related, because all the files compiled ok.
First one:
c:/program files/codesourcery/sourcery g++ lite/bin/…/lib/gcc/arm-none-eabi/4.3.2/…/…/…/…/arm-none-eabi/bin/ld.exe: error: no memory region specified for loadable section `.ARM.exidx’
I tried to solve it (or at least, make the code compile) adding the following lines to the lpc2368.ld file (I found googling around):
  /* .ARM.exidx is sorted, so has to go in its own output section.  */
  __exidx_start = .;
  .ARM.exidx :
    *(.ARM.exidx* .gnu.linkonce.armexidx.*)
  } >ram
  __exidx_end = .;
I have no idea if this is ok, but at least I dont get this error anymore…
But, now I got the following errors:
c:/program files/codesourcery/sourcery g++ lite/bin/…/lib/gcc/arm-none-eabi/4.3.2/…/…/…/…/arm-none-eabi/lib/thumb\libc.a(lib_a-sbrkr.o): In function `_sbrk_r’:
sbrkr.c:(.text+0xc): undefined reference to `_sbrk’
c:/program files/codesourcery/sourcery g++ lite/bin/…/lib/gcc/arm-none-eabi/4.3.2/…/…/…/…/arm-none-eabi/lib/thumb\libc.a(lib_a-writer.o): In function `_write_r’:
writer.c:(.text+0x10): undefined reference to `_write’
c:/program files/codesourcery/sourcery g++ lite/bin/…/lib/gcc/arm-none-eabi/4.3.2/…/…/…/…/arm-none-eabi/lib/thumb\libc.a(lib_a-closer.o): In function `_close_r’:
closer.c:(.text+0xc): undefined reference to `_close’
c:/program files/codesourcery/sourcery g++ lite/bin/…/lib/gcc/arm-none-eabi/4.3.2/…/…/…/…/arm-none-eabi/lib/thumb\libc.a(lib_a-fstatr.o): In function `_fstat_r’:
fstatr.c:(.text+0xe): undefined reference to `_fstat’
c:/program files/codesourcery/sourcery g++ lite/bin/…/lib/gcc/arm-none-eabi/4.3.2/…/…/…/…/arm-none-eabi/lib/thumb\libc.a(lib_a-isattyr.o): In function `_isatty_r’:
isattyr.c:(.text+0xc): undefined reference to `_isatty’
c:/program files/codesourcery/sourcery g++ lite/bin/…/lib/gcc/arm-none-eabi/4.3.2/…/…/…/…/arm-none-eabi/lib/thumb\libc.a(lib_a-lseekr.o): In function `_lseek_r’:
lseekr.c:(.text+0x10): undefined reference to `_lseek’
c:/program files/codesourcery/sourcery g++ lite/bin/…/lib/gcc/arm-none-eabi/4.3.2/…/…/…/…/arm-none-eabi/lib/thumb\libc.a(lib_a-readr.o): In function `_read_r’:
readr.c:(.text+0x10): undefined reference to `_read’
I am guessing it´s library related because of printf or something like it… What do I have to include explicitely ?
On the error messages, there´s references to libc.a , I tried to explicitely define -lc (no result). However in the demo projetct there is no explicit referente to any library.
Any sugestions?
THanks!
Sergio P. SIder
davedoors wrote on Tuesday, March 03, 2009:
Try compiling with Yagarto. See www.Yagarto.de.
deboeck wrote on Tuesday, March 03, 2009:
Dear Sergio,
  The Yagarto tools should do it. I have the lpc2368 Eclipse demo compiling with Eclipse (Europe) and Yagarto. Check the tutorial on http://www.freertos.org/Eclipse.html for installing/configuring Eclipse.
  OpenOSD might be usefull: http://openocd.berlios.de/web/.
Have fun,
Bart
sergiosider wrote on Wednesday, March 04, 2009:
Thank you guys,
I will try it, although the link for download in sourceforge is broken (yagarto). I managed to download the file googling around, although it´s not too safe to do it…
Thanks again,
Sergio P. Sider
hibouvn wrote on Tuesday, May 05, 2009:
Hi all,
I have followed the instructions to install Eclipse for testing the ARM7_LPC2368_Eclipse demo. But I have problem with the project’s compilation:
**** Build of configuration Default for project RTOSDemo ****
(Exec error:Launching failed)
I would like to know if I have to install some other additional tool or setting for compiling the project without error? Please help me. Thanks.
rtel wrote on Tuesday, May 05, 2009:
Check that the GCC compiler is in your path.
Open a command prompt and type "arm-elf-gcc", you should get a message saying something like "no input file specified".  If you get a message saying arm-elf-gcc is not a known program then you need to add the YAGARTO/bin directory to your PATH environment variable.
Next in the command prompt try typing "make".  Does it recognise that command?
Hi Richard,
It means that I have to install YAGATO as well? Anything else? Now I’ve just installed and configured Eclipse on my PC.
davedoors wrote on Tuesday, May 05, 2009:
Read the following page - http://www.freertos.org/portlpc2368_Eclipse.html
hibouvn wrote on Wednesday, May 06, 2009:
Thanks Dave, I can now launch the yagarto tool but still have problem with the compilation:
make all
arm-elf-gcc -c -g -O1 -Tlpc2368.ld -I . -I …/…/…/Source/include -I …/…/…/Source/portable/GCC/ARM7_LPC23xx -I …/…/Common/include -I ./webserver -I …/…/Common/ethernet/uIP/uip-1.0/uip -D ROWLEY_LPC23xx -D THUMB_INTERWORK -mcpu=arm7tdmi -D PACK_STRUCT_END=__attribute\(\(packed\)\) -D ALIGN_STRUCT_END=__attribute\(\(aligned\(4\)\)\) -fomit-frame-pointer -mthumb-interwork -mthumb main.c -o main.o
process_begin: CreateProcess(NULL, arm-elf-gcc -c -g -O1 -Tlpc2368.ld -I . -I …/…/…/Source/include -I …/…/…/Source/portable/GCC/ARM7_LPC23xx -I …/…/Common/include -I ./webserver -I …/…/Common/ethernet/uIP/uip-1.0/uip -D ROWLEY_LPC23xx -D THUMB_INTERWORK -mcpu=arm7tdmi -D PACK_STRUCT_END=__attribute((packed)) -D ALIGN_STRUCT_END=__attribute((aligned(4))) -fomit-frame-pointer -mthumb-interwork -mthumb main.c -o main.o, …) failed.
make (e=2): The system cannot find the file specified.
make: *** [main.o] Error 2
What is the solution?
Now I can pass this step but still error ‘cause some functions are not supported. Here some what I have from the output windows:
c:/program files/yagarto/bin/…/lib/gcc/arm-elf/4.3.3/…/…/…/…/arm-elf/lib/thumb/interwork\libg.a(lib_a-freer.o): In function `_malloc_trim_r’:
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdlib/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdlib/mallocr.c:3326: undefined reference to `_sbrk_r’
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdlib/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdlib/mallocr.c:3335: undefined reference to `_sbrk_r’
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdlib/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdlib/mallocr.c:3340: undefined reference to `_sbrk_r’
c:/program files/yagarto/bin/…/lib/gcc/arm-elf/4.3.3/…/…/…/…/arm-elf/lib/thumb/interwork\libg.a(lib_a-mallocr.o): In function `malloc_extend_top’:
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdlib/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdlib/mallocr.c:2160: undefined reference to `_sbrk_r’
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdlib/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdlib/mallocr.c:2197: undefined reference to `_sbrk_r’
c:/program files/yagarto/bin/…/lib/gcc/arm-elf/4.3.3/…/…/…/…/arm-elf/lib/thumb/interwork\libg.a(lib_a-makebuf.o): In function `__smakebuf_r’:
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdio/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdio/makebuf.c:59: undefined reference to `_fstat_r’
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdio/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdio/makebuf.c:110: undefined reference to `_isatty_r’
c:/program files/yagarto/bin/…/lib/gcc/arm-elf/4.3.3/…/…/…/…/arm-elf/lib/thumb/interwork\libg.a(lib_a-stdio.o): In function `__sclose’:
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdio/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdio/stdio.c:124: undefined reference to `_close_r’
c:/program files/yagarto/bin/…/lib/gcc/arm-elf/4.3.3/…/…/…/…/arm-elf/lib/thumb/interwork\libg.a(lib_a-stdio.o): In function `__sseek’:
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdio/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdio/stdio.c:106: undefined reference to `_lseek_r’
c:/program files/yagarto/bin/…/lib/gcc/arm-elf/4.3.3/…/…/…/…/arm-elf/lib/thumb/interwork\libg.a(lib_a-stdio.o): In function `__swrite’:
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdio/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdio/stdio.c:78: undefined reference to `_lseek_r’
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdio/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdio/stdio.c:86: undefined reference to `_write_r’
c:/program files/yagarto/bin/…/lib/gcc/arm-elf/4.3.3/…/…/…/…/arm-elf/lib/thumb/interwork\libg.a(lib_a-stdio.o): In function `__sread’:
C:\msys\1.0\home\yagarto\newlib-build\arm-elf\thumb\interwork\newlib\libc\stdio/…/…/…/…/…/…/…/newlib-1.17.0/newlib/libc/stdio/stdio.c:48: undefined reference to `_read_r’
collect2: ld returned 1 exit status
make: *** [RTOSDemo.elf] Error 1
Any idea?
jengoreda wrote on Thursday, August 13, 2009:
Hi all, i am facing this problem as well.
i am using codesourcery 2009q1-161-arm-none-eabi- with eclipse Galileo.
is there any update version of the demo code could be compiled by codesourcery 2009q1-161-arm-none-eabi- with eclipse Galileo?
Thanks very much.
please update me: xxxx@xxxx.com
egnascimento wrote on Friday, August 14, 2009:
Lao, you can fix it providin a syscalls.c file. That is because new newlib. Take a look at yagarto web site. They provide an example.
Let me help a little bit more. If you are using newlib 1.17, just create a file called syscalls.c like http://www.yagarto.de/download/yagarto/syscalls.c and compile together.
There is more information on http://www.yagarto.de/howto/yagarto1/yagarto_newlib.txt .
