I opended the following project FreeRTOSV8.2.3.exe > FreeRTOS > Demo > ARM7_LPC2368_Eclipse
with current eclipse-cpp-mars-1-win32-x86_64
and GNU Tools ARM Embedded gcc-arm-none-eabi-5_2-2015q4-20151219-win32.exe
and GNU ARM Eclipse Build Tools gnuarmeclipse-build-tools-win64-2.6-201507152002-setup.exe
under Windows 7 x64
While installation I replaced all . by _ because I read that . in path could cause problems.
I get the following error:
Program “arm-elf-gcc” not found in PATH
Resolution from http://stackoverflow.com/questions/20412100/discovery-options-in-eclipse-c-c
Kepler hides “Discovery Options” by default. Go to Window->Preferences-> C/C++ > Property Pages Settings and check display discovery option page. Then, open your project preferences and change arm-elf-gcc to arm-none-eabi-gcc like the rest.
I tested this but I couldn’t find the option.
Resolution from https://wiki.ubuntuusers.de/Archiv/GNUARM-Toolchain/
Das PPA installiert arm-none-eabi-gcc, nicht arm-elf-gcc wie im Rest des Tutorials. Das Target arm-elf wird ab GCC 4.8 nicht mehr unterstützt. In der Bedienung unterscheiden sich arm-none-eabi-gcc und arm-elf-gcc nicht.
Do you have the arm-none-eabi-gcc compiler installed on your host and in the system path? It is not part of the Eclipse install and installed separately.
That means the compiler is installed. What is the issue you have then? If it is calling arm-elf-gcc but the compiler is arm-none-eabi-gcc then you will need to update the project to use the right compiler.
