system
(system)
1
anhuly wrote on Thursday, December 20, 2007:
I got the following error in eclipse console when I compile LPC2368 Webserver project
**** Build of configuration Default for project RTOSDemo ****
(Exec error:Launching failed)
much appreciated if you help me with this
thank you
system
(system)
2
davedoors wrote on Thursday, December 20, 2007:
Do you have the bin directory of your compiler in your PATH environment? Also do you have make in the path?
Open a command prompt and type arm-elf-gcc. Is the command recognized. Do the same typing make.
