nobody wrote on Tuesday, April 24, 2007:
I got Sourcecode from this site. I have Window XP OS and Intel processor. Now i want to build this RTOS , how can i do it without any application. or can you give me link where this explain? it will be useful
Try this port: http://www.freertos.org/a00100.html
nobody wrote on Wednesday, April 25, 2007:
If we consider that , we have only three folder Source,TraceCon, License. How can we build kernel? is it require Makefile ?Please help me in this
Where did you get your download from. You should have a demo directory also which includes a project file or makefile for each port. RTFM: http://www.freertos.org/a00017.html
Dave.
Ya it has Demo folder also.
Question
1. Can’t we build kernal without application(Demo dir).
2. I have Window XP OS and Intel processor. In Demo folder i think PC folder is for Window host. I can see three folder and main.c some “.h " file “.dsw “,”.tgt”,”.wpj"
using this how can i build Kernal
Can anyone explain procedure how to do it.
Again, https://sourceforge.net/forum/message.php?msg_id=4279251
you have already been given the page reference that holds the instructions.
Actually, https://sourceforge.net/forum/message.php?msg_id=4278078
Watcom Development tool is needed for Windows ? i have read in FAQs.
nobody wrote on Friday, April 27, 2007:
I have read both links which u refered. but it is saying about makefile so i have to make it for PC? that refers to project file also. is it .wpj? I have download Watcom tool to run RTOS . In that page it is saying that "Use Development Switches" But that option is not enable only. help me in this
1) Install Watcom tools
2) Download FreeRTOS zip file and unzip.
3) In the Watom IDE, open the project file that is in the FreeRTOS/Demo/PC directory.
4) Compile.
5) Set NO87=1 in as an environment variable.
6) Run.
This information is all in the documentation.
nobody wrote on Monday, April 30, 2007:
After compiling It is giving error
: cannot open clibl.lib :no such file or directory
Error!E2028:_bib_code_ is undefined reference
Many undefined references
Error!3137:too many errors encountered
what to do?
When you install OW, you get the option to install the DOS tools as well as the win32 tools. As you are creating a DOS exe you need to check the box to ensure the DOS tools. Did you do this? As the library is not found I think you did not install the DOS files.
I have set environment variable NO87=1 to path C:\FreeRTOS\Demo\PC
After i run it , It is giving message
COM RX task started.
Blocking queue consumer started.
Math task 1 started.
Multi event controller task started.
Com test count unchanged!
rtosdemo.exe generated in PC folder. when i click it gives message "The system cannot open COM1 port requested by the application."
what will be problem?
nobody wrote on Wednesday, May 02, 2007:
Anybody know the solution then please let me know it.
