I want to simulate MultiTasking environment on my PC (with windows XP and over AMD Athlon dual core),
I have read the documentation on the “http://www.freertos.org/” site, and I’m a little bit confused from the explanation there.
I tried to compile the project of “Demo\PC” directory, after downloading the zip file of version 6.0.5 of FreeRTOS.
The compilation was failed.
I tried to create new project with the same files and definitions of the existing project,
but I’ve realized that it was impossible, since there are some definitions that I couldn’t find in open watcom (version 1.8)
1. Is that directory (Demo\PC) what I need in order to do such simulation?
2. In case that the Demo\PC is the correct directory I need,
What should be the watcom definitions for:
* memory model,
* target processor,
* Linker system ?
The Demo/PC directory contains an Open Watcom project that should contain everything you need, so all you have to do is open the project. Make sure you have the 16bit version of the Open Watcom tools installed though, it is an option during the installation process.
You are right. The 16-bit option was not checked, when I installed the watcom. I installed it again, and now it can be compiled.
I assume that your answer for my first question is: ‘Yes’, meaning that this is the way for simulating RT embedded environment
on my PC…? (I haven’t yet looked deeply inside the tasks code)
