I am newbie to the FreeRTOS. I am trying the learn the FreeRTOS with the book “Unsing the FreeRTOS Reasl Time Kernel - A Paractical Guide” wrote by Richard Barry.
I am trying to complie the examples in these book with Open Watcon as recommended in the book.
But I get the following errors:
Warning! W1008 cannot open clibl.lib Noch such file or directory
I am not fimilar with Open Watcom IDE
Any one has idea how can I get the example running!!!
When you installed the compiler, did you install the 16 bit tools? It compiles to Real mode, so requires the old 16bit compiler. It is an option when you first run the OpenWatcom installer.
