I am setting up an application running on a custom board with the STM32F302RC (Cortex M4F, floating point enabled). I’m using the LL drivers only (no HAL).
I haven’t used FreeRTOS much in the past, and never on the ST family. My simple test app configures the processor, creates a single task, and starts it.
int main() {
platform_init();
SWO_PrintString("hello world!\n",0);
startUartRx();
xTaskCreate(defaultTask, "Default", 32, NULL,tskIDLE_PRIORITY+1, NULL);
xPortStartScheduler();
while (1) {
return 0;
This is the task itself:
static void defaultTask(void * params) {
for (;;) {
vTaskDelay(pdMS_TO_TICKS(500));
LL_GPIO_SetOutputPin(aux_GPIO_Port, aux_Pin);
LL_GPIO_ResetOutputPin(aux_GPIO_Port, aux_Pin);
And this doesn’t work. Nothing seems to happen, and when I stop in the debugger, I’m always at the call to taskSELECT_HIGHEST_PRIORITY_TASK in vTaskSwitchContext(), tasks.c:
#endif /* configGENERATE_RUN_TIME_STATS */
/* Check for stack overflow, if configured. */
taskCHECK_FOR_STACK_OVERFLOW();
/* Select a new task to run using either the generic C or port
optimised asm code. */
taskSELECT_HIGHEST_PRIORITY_TASK(); // <---- Always here
traceTASK_SWITCHED_IN();
#if ( configUSE_NEWLIB_REENTRANT == 1 )
/* Switch Newlib's _impure_ptr variable to point to the _reent
structure specific to this task. */
_impure_ptr = &( pxCurrentTCB->xNewLib_reent );
#endif /* configUSE_NEWLIB_REENTRANT */
However, if I create a second empty task, now the first task works and my GPIO output toggles on and off:
int main() {
platform_init();
startUartRx();
xTaskCreate(secondTask, "Second", 32, NULL,tskIDLE_PRIORITY, NULL); //<---- 2nd task, now first task runs
while (1) {
return 0;
void secondTask(void * params) {
for (;;) {
Any thoughts? Seems like an issue with my interrupt configuration, since vTaskSwitchContext is called from PendSV_Handler.
My FreeRTOSConfig.h:
* FreeRTOS Kernel V10.0.1
* Copyright (C) 2017 Amazon.com, Inc. or its affiliates. All Rights Reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy of
* this software and associated documentation files (the "Software"), to deal in
* the Software without restriction, including without limitation the rights to
* use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
* the Software, and to permit persons to whom the Software is furnished to do so,
* subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* http://www.FreeRTOS.org
* http://aws.amazon.com/freertos
* 1 tab == 4 spaces!
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
* this is a template configuration files
* These definitions should be adjusted for your particular hardware and
* application requirements.
* These parameters and more are described within the 'configuration' section of the
* FreeRTOS API documentation available on the FreeRTOS.org web site.
* See http://www.freertos.org/a00110.html
/* Ensure stdint is only used by the compiler, and not the assembler. */
#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
#include <stdint.h>
extern uint32_t SystemCoreClock;
/* CMSIS-RTOSv2 defines 56 levels of priorities. To be able to use them
* all and avoid application misbehavior, configUSE_PORT_OPTIMISED_TASK_SELECTION
* must be set to 0 and configMAX_PRIORITIES to 56
/* #define configUSE_PORT_OPTIMISED_TASK_SELECTION 0*/
/* #define configMAX_PRIORITIES ( 56 ) */
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configMAX_PRIORITIES (7)
#define configSUPPORT_STATIC_ALLOCATION 0
#define configCPU_CLOCK_HZ (SystemCoreClock)
#define configTICK_RATE_HZ ((TickType_t)1000)
#define configMINIMAL_STACK_SIZE ((uint16_t)128)
#define configTOTAL_HEAP_SIZE ((size_t)(4096))
#define configMAX_TASK_NAME_LEN (16)
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 8
#define configCHECK_FOR_STACK_OVERFLOW 0
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_MALLOC_FAILED_HOOK 0
#define configUSE_APPLICATION_TASK_TAG 0
#define configUSE_COUNTING_SEMAPHORES 1
#define configGENERATE_RUN_TIME_STATS 0
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES (2)
/* Software timer definitions. */
#define configUSE_TIMERS 0
#define configTIMER_TASK_PRIORITY (2)
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH (configMINIMAL_STACK_SIZE * 2)
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 0
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetSchedulerState 1
/*------------- CMSIS-RTOS V2 specific defines -----------*/
/* When using CMSIS-RTOSv2 set configSUPPORT_STATIC_ALLOCATION to 1
* is mandatory to avoid compile errors.
* CMSIS-RTOS V2 implmentation requires the following defines
#define configSUPPORT_STATIC_ALLOCATION 1 <-- cmsis_os threads are created using xTaskCreateStatic() API
#define configMAX_PRIORITIES (56) <-- Priority range in CMSIS-RTOS V2 is [0 .. 56]
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 0 <-- when set to 1, configMAX_PRIORITIES can't be more than 32 which is not suitable for the new CMSIS-RTOS v2 priority range
/* the CMSIS-RTOS V2 FreeRTOS wrapper is dependent on the heap implementation used
* by the application thus the correct define need to be enabled from the list
* below
//define USE_FreeRTOS_HEAP_1
//define USE_FreeRTOS_HEAP_2
//define USE_FreeRTOS_HEAP_3
//define USE_FreeRTOS_HEAP_4
//define USE_FreeRTOS_HEAP_5
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4 /* 15 priority levels */
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0xf
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
#define configASSERT( x ) if( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names. */
/* IMPORTANT: FreeRTOS is using the SysTick as internal time base, thus make sure the system and peripherials are
using a different time base (TIM based for example).
Thanks,
Philip
