martin-etla wrote on Tuesday, June 18, 2019:
MCU: STM32F030
FreeRTOS: 10.2.1
Toolchain: gcc-arm-none-eabi-8-2018-q4-major-linux.tar.bz2
Debugger: Segger Ozone V2.62, Win 10 x64
I’m stumped. Consider this code:
void task1(void *x)
(void)x;
while (1)
HAL_GPIO_WritePin(GPIOC, LD3_Pin, GPIO_PIN_SET);
vTaskDelay(configTICK_RATE_HZ);
HAL_GPIO_WritePin(GPIOC, LD3_Pin, GPIO_PIN_RESET);
void task2(void *x)
(void)x;
while (1)
HAL_GPIO_WritePin(GPIOC, LD4_Pin, GPIO_PIN_SET);
vTaskDelay(configTICK_RATE_HZ*1.3);
HAL_GPIO_WritePin(GPIOC, LD4_Pin, GPIO_PIN_RESET);
void task3(void *x)
(void)x;
while (1)
int main()
MX_GPIO_Init();
xTaskCreate(task1, "test1", 100, 0, tskIDLE_PRIORITY, 0);
xTaskCreate(task2, "test2", 100, 0, tskIDLE_PRIORITY, 0);
xTaskCreate(task3, "test3", 100, 0, tskIDLE_PRIORITY, 0);
xPortStartScheduler();
while (1)
return 0;
This works perfectly, but if I add a vTaskDelay in task3 or comment out the xTaskCreate for task3 the kernel gets stuck in xTaskRemoveFromUnorderedEventList (in tasks.c) according to the debugger. If I look into the assembler it looks like:
0800136c <vTaskSwitchContext>:
800136c: b580 push {r7, lr}
800136e: b082 sub sp, #8
8001370: af00 add r7, sp, #0
8001372: 4b22 ldr r3, [pc, #136] ; (80013fc <vTaskSwitchContext+0x90>)
8001374: 681b ldr r3, [r3, #0]
8001376: 2b00 cmp r3, #0
8001378: d003 beq.n 8001382 <vTaskSwitchContext+0x16>
800137a: 4b21 ldr r3, [pc, #132] ; (8001400 <vTaskSwitchContext+0x94>)
800137c: 2201 movs r2, #1
800137e: 601a str r2, [r3, #0]
8001380: e037 b.n 80013f2 <vTaskSwitchContext+0x86>
8001382: 4b1f ldr r3, [pc, #124] ; (8001400 <vTaskSwitchContext+0x94>)
8001384: 2200 movs r2, #0
8001386: 601a str r2, [r3, #0]
8001388: 4b1e ldr r3, [pc, #120] ; (8001404 <vTaskSwitchContext+0x98>)
800138a: 681b ldr r3, [r3, #0]
800138c: 607b str r3, [r7, #4]
800138e: e007 b.n 80013a0 <vTaskSwitchContext+0x34>
8001390: 687b ldr r3, [r7, #4]
8001392: 2b00 cmp r3, #0
8001394: d101 bne.n 800139a <vTaskSwitchContext+0x2e>
8001396: b672 cpsid i
It's stuck in an infinite loop here:
8001398: e7fe b.n 8001398 <vTaskSwitchContext+0x2c>
800139a: 687b ldr r3, [r7, #4]
800139c: 3b01 subs r3, #1
800139e: 607b str r3, [r7, #4]
80013a0: 4919 ldr r1, [pc, #100] ; (8001408 <vTaskSwitchContext+0x9c>)
So it conforms that it’s stuck without being able to task switch, but I simply can’t figure out why. I’ve checked the vector table and it seems fine with the correct vectors pointing at SVC_Handler, PendSV_Handler and SysTick_Handler.
If I add a break point in xPortSysTickHandler it activates if task3 is running as an infinite loop but it’s not even called once if I either disable task3 or add a vTaskDelay in it.
So as I said, I’m stumped. And I’ve googled myself silly.
Help?
