hfquincy wrote on Wednesday, March 26, 2008:
Hellor everybody,
I setup up eclipse and the FreeRTOS_ROOT variable and wanted to compile and link the project but I got several error messages. I am not firm with the arm architechture and the eclipse / yagarto package. What can I do to solve the following errors:
**** Build of configuration Default for project web_server ****
make all
arm-elf-gcc -c -g -O3 -Tatmel-rom.ld -I . -I …/…/…/Source/include -I …/…/…/Source/portable/GCC/ARM7_AT91SAM7S -I …/…/Common/include -I ./webserver -I …/…/Common/ethernet/uIP/uip-1.0/uip -I ./SrcAtmel -I ./USB -D SAM7_GCC -D THUMB_INTERWORK -mcpu=arm7tdmi -D PACK_STRUCT_END=__attribute\(\(packed\)\) -D ALIGN_STRUCT_END=__attribute\(\(aligned\(4\)\)\) -fomit-frame-pointer -mthumb-interwork -mthumb main.c -o main.o
main.c:78:22: error: FreeRTOS.h: No such file or directory
main.c:79:18: error: task.h: No such file or directory
main.c:82:21: error: partest.h: No such file or directory
In file included from main.c:83:
./USB/USBSample.h:58: error: expected ‘:’, ‘,’, ‘;’, ‘}’ or ‘__attribute__’ before ‘ulISR’
./USB/USBSample.h:87: error: expected ‘;’, ‘,’ or ‘)’ before ‘uxPriority’
main.c:85:20: error: BlockQ.h: No such file or directory
main.c:86:22: error: blocktim.h: No such file or directory
main.c:87:19: error: flash.h: No such file or directory
main.c:88:19: error: QPeek.h: No such file or directory
main.c:89:21: error: dynamic.h: No such file or directory
main.c: In function ‘main’:
main.c:127: error: ‘configMINIMAL_STACK_SIZE’ undeclared (first use in this function)
main.c:127: error: (Each undeclared identifier is reported only once
main.c:127: error: for each function it appears in.)
main.c:127: error: ‘tskIDLE_PRIORITY’ undeclared (first use in this function)
main.c: In function ‘prvSetupHardware’:
main.c:162: error: ‘AT91C_BASE_AIC’ undeclared (first use in this function)
main.c:168: error: ‘AT91C_BASE_PMC’ undeclared (first use in this function)
main.c:168: error: ‘AT91C_ID_PIOA’ undeclared (first use in this function)
main.c:169: error: ‘AT91C_ID_PIOB’ undeclared (first use in this function)
main.c:170: error: ‘AT91C_ID_EMAC’ undeclared (first use in this function)
main.c: In function ‘vApplicationTickHook’:
main.c:179: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘ulCallCount’
main.c:179: error: ‘ulCallCount’ undeclared (first use in this function)
main.c:179: error: ‘ulErrorFound’ undeclared (first use in this function)
main.c:179: error: ‘pdFALSE’ undeclared (first use in this function)
main.c:183: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘ulErrorFlashRate’
main.c:183: error: ‘ulErrorFlashRate’ undeclared (first use in this function)
main.c:183: error: ‘portTICK_RATE_MS’ undeclared (first use in this function)
main.c:187: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘ulNoErrorCheckRate’
main.c:187: error: ‘ulNoErrorCheckRate’ undeclared (first use in this function)
main.c:210: error: ‘pdTRUE’ undeclared (first use in this function)
make: *** [main.o] Error 1
It seems that there are still some problems with the root variable. I have copied the FreeRTOS folder into C:\CAD\FreeRTOS\ and put that path into the "linked Ressources" settings. Where could the reason for that problem be located? Any suggestions?
Best Regards
Dirk
