GeorgesOvon wrote on November 19, 2018:
Hi, I am new to AWS freertos. I am working on NXP-1050 devkit board, and tryin gto get evkbimxrt1050_aws_shadow_enet example program to run.
I have (tried) to following the instructions, but when I run the result, I get the log messages below.
“Command sent to MQTT task failed”
The AWS seems to register that a connection has been made, so I think the certificates are working. I think I must have missed a step.
Any help is welcome.
0 0 [Tmr Svc] Starting key provisioning…
1 0 [Tmr Svc] Write root certificate…
2 21 [Tmr Svc] Write device private key…
3 353 [Tmr Svc] Write device certificate…
4 367 [Tmr Svc] Key provisioning done…
5 26146 [Tmr Svc] Getting IP address from DHCP …
6 28146 [Tmr Svc] IPv4 Address: 192.168.1.130
7 28146 [Tmr Svc] DHCP OK
8 28152 [MainDemoTask] [Shadow 0] MQTT: Creation of dedicated MQTT client succeeded.
9 28160 [MainDemoTask] Sending command to MQTT task.
10 28164 [MQTT] Received message 10000 from queue.
11 28798 [MQTT] About to close socket.
12 28798 [MQTT] Socket closed.
13 28799 [MQTT] Notifying task.
14 28808 [MainDemoTask] Command sent to MQTT task failed.
15 28813 [MainDemoTask] [Shadow 0] MQTT: Connect failed.
16 28818 [MainDemoTask] Shadow_ClientConnect unsuccessful, returned 2.
17 28825 [MainDemoTask] Failed to initialize Shadow client.
