AWS MQTT Demo MbedTLS Config
Hi, I am trying to connect to AWS using the MQTT demo for STM32L4. I have tweaked some of the project settings such as NOT to use offload_ssl.
I know that the certs and private key are correct as I used them with a mosquitto client to connect successfully.
During the handshake process at step 12, I get fatal message errors (-0x7780, msg 40), which according to some forums may be related to the cipher suite used.
I have not tweaked the config.h file for mbedtls that came with the demo project, but I am wondering if there is something that should be modified.
Anyone have ideas?
Thanks!!
Did you use our quick connect workflow to generate cert and keys and setup other AWS resources required for the demo?
Just to make sure that your cert and keys are correct, would you please use with offload_ssl and let us know if that works.
Also, what version of the code are you using?
Yep, I used the quick connect to gen the cert and private key. I am confident that they are correct as I was able to load them into another program to connect to AWS and publish to mqtt topics.
I actually cannot use offload_ssl. The demo is running on custom hardware with a cell module instead of wifi module. ( so of course i tweaked some of the functionality to communicate with the cell modem vs the wifi chip)
The version of code I have is 0.9.2 for the aws config
FreeRTOS V202002.00
mbed TLS 2.16.0
Okay - So you are porting to a new hardware. In that case, it will be helpful to take a step-by-step approach:
  1. Let’s first make sure that the TCP stack works correctly. Which TCP stack are you using? Are you porting to our secure sockets layer - in which case you can use our secure socket tests to verify that the TCP works correctly.
  2. After we are sure that the TCP layer is working as expected, we can move to TLS. Our secure sockets tests include TLS tests as well which helps you to verify that TLS+TCP works correctly.
  3. Next we can bring in MQTT and connect to AWS IoT.
Would you also enable mbedTLS debug logs and share them.
Hi Gaurav,
I am using LwIP, yes porting to the secure sockets layer.
I verified the TCP stack is working by opening a socket to the U-blox echo server (we are using a ublox modem) and can send and receive responses.
Does AWS have a test server that can be used for the secure sockets TLS tests? Should I just use my endpoint/keys/certs for the test?
I noticed that the handshake is failing at state 12 of the mbed tls handshake…SSL_SERVER_CHANGE_CIPHER_SPEC which makes me think that there is something off with the config.h being used.
I updated the config file, and and now getting a fatal message 42 type:
70606 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => handshake
70723 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 0
70849 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
70975 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
71101 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 1
71227 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
71353 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
71479 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write client hello
71623 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write handshake message
71767 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write record
71893 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
72019 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: message length: 158, out_left: 158
72391 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_send() returned 158 (-0xffffff62)
72553 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
72679 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write record
72805 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write handshake message
72946 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write client hello
73081 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 2
73207 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
73333 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
73459 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => parse server hello
73594 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => read record
73717 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => fetch input
73840 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 0, nb_want: 5
75386 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 0, nb_want: 5
75521 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
75707 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= fetch input
75830 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => fetch input
75953 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 5, nb_want: 5348
76145 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 5, nb_want: 5348
76286 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_recv(_timeout)() returned 1375 (-0xfffffaa1)
77076 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 1380, nb_want: 5348
77220 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_recv(_timeout)() returned 1380 (-0xfffffa9c)
81990 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 2760, nb_want: 5348
82134 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_recv(_timeout)() returned 1380 (-0xfffffa9c)
83385 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 4140, nb_want: 5348
83529 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_recv(_timeout)() returned 1208 (-0xfffffb48)
83709 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= fetch input
83847 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= read record
83970 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: server hello, total extension length: 9
84132 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= parse server hello
84267 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 3
84393 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
84519 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
84645 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => parse certificate
84777 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => read record
85017 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= read record
87089 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= parse certificate
87221 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 4
87347 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
87473 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
87599 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => parse server key exchange
87743 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => read record
87872 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= read record
87998 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ECDH curve: secp256r1
88130 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: Server used SignatureAlgorithm 1
88280 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: Server used HashAlgorithm 4
89252 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= parse server key exchange
89396 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 5
89522 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
89648 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
89774 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => parse certificate request
89918 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => read record
90041 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= read record
90164 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= parse certificate request
90308 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 6
90434 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
90560 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
90686 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => parse server hello done
90827 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => read record
90950 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= read record
91073 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= parse server hello done
91214 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 7
91340 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
91466 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
91592 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write certificate
91727 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write handshake message
91883 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write record
92009 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
92135 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: message length: 876, out_left: 876
93278 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_send() returned 876 (-0xfffffc94)
93440 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
93566 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write record
93692 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write handshake message
93833 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write certificate
93965 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 8
94091 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
94217 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
94343 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write client key exchange
111518 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write handshake message
111665 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write record
111788 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
111914 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: message length: 75, out_left: 75
112199 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_send() returned 75 (-0xffffffb5)
112361 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
112487 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write record
112613 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write handshake message
112757 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write client key exchange
112904 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 9
113030 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
113156 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
113282 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write certificate verify
113426 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => derive keys
113552 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => calc verify sha256
113690 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= calc verify
113966 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= derive keys
114089 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => calc verify sha256
114227 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= calc verify
123491 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write handshake message
123638 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write record
123761 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
123887 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: message length: 85, out_left: 85
124184 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_send() returned 85 (-0xffffffab)
124346 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
124472 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write record
124598 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write handshake message
124742 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write certificate verify
124886 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 10
125015 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
125153 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
125279 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write change cipher spec
125423 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write handshake message
125567 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write record
125693 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
125819 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: message length: 6, out_left: 6
126026 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_send() returned 6 (-0xfffffffa)
126188 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
126314 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write record
126440 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write handshake message
126584 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write change cipher spec
126728 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 11
126857 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
126983 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
127109 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write finished
127238 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => calc finished tls sha256
127406 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= calc finished
127535 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write handshake message
127682 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => write record
127805 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => encrypt buf
127934 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= encrypt buf
128060 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
128186 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: message length: 45, out_left: 45
128342 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_send() returned 45 (-0xffffffd3)
128501 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
128627 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write record
128753 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write handshake message
128897 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= write finished
129026 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: client state: 12
129155 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => flush output
129281 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= flush output
129407 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => parse change cipher spec
129551 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => read record
129677 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => fetch input
129803 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 0, nb_want: 5
129941 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 0, nb_want: 5
130079 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
130256 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= fetch input
130396 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: => fetch input
130522 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 5, nb_want: 7
130660 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: in_left: 5, nb_want: 7
130798 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: ssl->f_recv(_timeout)() returned 2 (-0xfffffffe)
130975 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= fetch input
131102 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: got an alert message, type: [2:42]
131282 - info:prvTlsDebugPrint:723:mbedTLS: |1| 0x2000ed04: is a fatal alert message (msg 42)
131435 - info:prvTlsDebugPrint:723:mbedTLS: |1| 0x2000ed04: mbedtls_ssl_handle_message_type() returned -30592 (-0x7780)
131627 - info:prvTlsDebugPrint:723:mbedTLS: |1| 0x2000ed04: mbedtls_ssl_read_record() returned -30592 (-0x7780)
131807 - info:prvTlsDebugPrint:723:mbedTLS: |2| 0x2000ed04: <= handshake
We do not provide a test server as a hosted solution but we do provide two simple echo servers written in GO. This page explains how to set up TLS and non-TLS echo servers: FreeRTOS
Please setup TLS echo server and lets see if that works. Meanwhile I will try to get more information on the logs you shared.
In addition to Gaurav’s guidance, can you set the mbedtls debug level to 4?
Also here are the supported cipher specs for AWS IoT Core: https://docs.aws.amazon.com/iot/latest/developerguide/transport-security.html.
Perhaps you can cross reference this with your config.h. Albeit that seems to not be the issue if it has not been changed from the one we distribute.
Hello Audreyh,
I took a look at those logs, and you are receiving an alert message 42 from the server. This indicates a bad certificate. Could you be missing some initialization / configuration code? Or possibly missing a certificate in the
Since you’ve tested this certificate with another program it is likely a problem when porting to the secure sockets layer.
Have you followed our porting guide? https://docs.aws.amazon.com/freertos/latest/portingguide/afr-porting-ss.html. It may also be helpful to compare to the existing not offload_ssl port on ST.
Thanks,
Carl
Hi Carl…thanks for the response! I think the rest of this sentence got cut off: “Or possibly missing a certificate in the”
What was the rest of that sentence?
There could be some init code missing, I have the function vDevModeKeyProvisioning() running at startup, but maybe I am missing another item related to the certificate, I will cross reference with the demos one more time.
Apologies for the typo! “Or possibly missing a certificate in the certificate chain" was the complete sentence.
This file may be a useful resource for some example code that uses mbedTLS. https://github.com/aws/amazon-freertos/blob/master/libraries/freertos_plus/standard/tls/src/iot_tls.c.
