Hi, I am trying to connect my evkbimxrt1050 board (Murata 1DX M.2 module + Murata uSD M.2 Adapter) to AWS using the demos “shadow_wiced” for days now.
When I change the aws_clientcredential to connect my wifi it could connect to wifi but throws errors like ERROR(15878) Failed to establisch new connection. Socket Status: -8576
If I replace the clientcredential_keys.h with the one I created I got this:
The above log shows that the demo has completed successfully - look “Demo Completed Successfully” message. This means that your certificate, keys and the associated policies are correct.
Are you trying to port our code to this board or is this an existing port?
Hi aggarg,
thanks for replying.
I know this means it was successful but I am not able to reproduce it. It seems to be random. Somestimes it will work, sometimes not. Maybe the power only via USB is too low?
It is an existing port. I only changed aws_clientcredentials (SSID, password, endpoint and thing name) and the clientcredientials_key file.
Hi Joshua,
it’s from SDK Version 2.8.2.
Do you need any further details?
Sorry, I should say that I am totally new to this.
I think will capture a video later on to make sure that I click nothing wrong.
Best
Max
Edit: I just started the pc, plug the board in and had terra term open and the demo runs but I can’t reproduce it . Maybe it has something to do that the board get power only via usb (the debug port). I already ordered a barrel jack connector.
Does that mean that the issue is with the debugging setup? Can you try not to debug but just flash the board and then run it multiple times by resetting the board? Keep the Tera Term open so that you see the output.
Exactly. I just plugged the board in socket usb adapter und received output in aws mqtt console. I will try it several times tomorrow. Thank you for your input!
Is there a setting to change for debugging?
So it will always work once. After starting my PC when I connect the board to my laptop the demo will run fine but a second time. Even reconnect wont help. Only shutting down and wait.
It seems to be an hardware problem and not a software problem?
thanks for reply. I studied the Getting Started Document before but I have no licence for IAR and I struggled to work with CMAKE so I switched to MCUXpresso.
External power supply does not solve the problem. SW7 is on-off-off-on, correct?
By the way, the problem only exists with aws. The other demos will always work fine.
Any Jumper that has to be changed for aws?
no need to apology here. I am very thankful for your help! Nevertheless I am bit frustrated that I have issues with demo apps.
Attached you will find what is in mflash:file.c - no changes made here.
I have a feeling that my problem has something do to with the priorities of the tasks but I have no idea how to solve this. I will go trough the link you provided. Thanks so far.
Could someone check my freeRTOSConfig.h (attached), please?
I have to admit that I am a absolute beginner to this. Sorry! Please let me know if you need any further information.FreeRTOSConfig.h (9.5 KB)
Edit: I am pretty sure that it has something to do with my task priorities…
Looking at the line #149return pdTRUE;, it is either return address (which is stored in LR) is corrupted or data access violation is imprecise. Would you please put a breakpoint at this line and share the call-stack? Also, how do you conclude that it is an issue with task priorities?
