system
(system)
April 7, 2017, 5:43pm
1
richdinoso wrote on Friday, April 07, 2017 :
I am working with the EFM32 GG starter kit. I’m testing the blink LED demo that comes with Simplicity Studio. In FreeRTOSConfig.h there is this line:
#define configCPU_CLOCK_HZ (( unsigned long ) 14000000)
When I change the value to 24000000 the length of vTaskDelay increases as well. Is there another #define that needs to be changed in conjunction?
configTICK_RATE_HZ is 1000, and the number of ticks being passed to vTaskDelay is correctly calculated.
The task definition and creation:
static void LedBlink(void *pParameters)
TaskParams_t * pData = (TaskParams_t*) pParameters;
const portTickType delay = pData->delay;
for (;;)
BSP_LedToggle(pData->ledNo);
vTaskDelay(delay);
/* Parameters value for taks*/
static TaskParams_t parametersToTask1 = { pdMS_TO_TICKS(1000), 0 };
static TaskParams_t parametersToTask2 = { pdMS_TO_TICKS(1000), 1 };
/*Create two task for blinking leds*/
xTaskCreate( LedBlink, (const char *) "LedBlink1", STACK_SIZE_FOR_TASK, ¶metersToTask1, TASK_PRIORITY, NULL);
xTaskCreate( LedBlink, (const char *) "LedBlink2", STACK_SIZE_FOR_TASK, ¶metersToTask2, TASK_PRIORITY, NULL);
rtel
(Richard Barry)
April 7, 2017, 6:17pm
2
rtel wrote on Friday, April 07, 2017 :
Is this using Systick to generate the tick interrupt? Or is it using a
low power clock along with some low power modes?
system
(system)
April 7, 2017, 7:44pm
3
This is the function that sets up the tick interrupt.
__attribute__(( weak )) void vPortSetupTimerInterrupt( void )
/* Calculate the constants required to configure the tick interrupt. */
#if configUSE_TICKLESS_IDLE == 1
ulTimerCountsForOneTick = ( configSYSTICK_CLOCK_HZ / configTICK_RATE_HZ );
xMaximumPossibleSuppressedTicks = portMAX_24_BIT_NUMBER / ulTimerCountsForOneTick;
ulStoppedTimerCompensation = portMISSED_COUNTS_FACTOR / ( configCPU_CLOCK_HZ / configSYSTICK_CLOCK_HZ );
#endif /* configUSE_TICKLESS_IDLE */
/* Configure SysTick to interrupt at the requested rate. */
portNVIC_SYSTICK_LOAD_REG = ( configSYSTICK_CLOCK_HZ / configTICK_RATE_HZ ) - 1UL;
portNVIC_SYSTICK_CTRL_REG = ( portNVIC_SYSTICK_CLK_BIT | portNVIC_SYSTICK_INT_BIT | portNVIC_SYSTICK_ENABLE_BIT );
configSYSTICK_CLOCK_HZ = 14000000, configTICK_RATE_HZ = 1000
ulTimerCountsForOneTick = 14000
rtel
(Richard Barry)
April 7, 2017, 7:53pm
4
As you say:
is it right that configUSE_TICKLESS_IDLE is set to 1? If so, could you
try setting it to 0 and see if you observe the same behaviour, or if
that fixes the issue. That will narrow down where we need to look.
system
(system)
April 7, 2017, 7:58pm
5
The debugger runs into that code, so configUSE_TICKLESS_IDLE is sure set to 1. I already tried setting it to 0, but I did it again just now to double check. The behavior is the same.
system
(system)
April 10, 2017, 2:57pm
6
richdinoso wrote on Monday, April 10, 2017 :
Someone pointed out that changing this value does not actually change my clock. Sorry for the misunderstanding. Thread closed.
