i’m uploading my port.c file here. Can you please explain me a "void vPortSetupTimer(void); " function. because this function itself setups the timer to generate the tick interrupts. but I didn’t got an idea that which subroutines are performed within this function. please kindly explain.
/* Scheduler includes. */
#include “FreeRTOS.h”
#include “task.h”
#include “portmacro.h”
#include “riscv_hal.h”
#ifdef __riscv64
define STORE sd
define LOAD ld
define REGBYTES 8
#else
define STORE sw
define LOAD lw
define REGBYTES 4
/* A variable is used to keep track of the critical section nesting. This
variable has to be stored as part of the task context and must be initialized to
a non zero value to ensure interrupts don’t inadvertently become unmasked before
the scheduler starts. As it is stored as part of the task context it will
automatically be set to 0 when the first task is started. */
static UBaseType_t uxCriticalNesting = 0xaaaaaaaa;
/* Contains context when starting scheduler, save all 31 registers */
#ifdef __gracefulExit
BaseType_t xStartContext[31] = {0};
typedef struct
uint32_t val_low;
uint32_t val_high;
}riscv_machine_timer_t;
static volatile riscv_machine_timer_t *mtime = (riscv_machine_timer_t *)0x4400BFF8;
static volatile riscv_machine_timer_t *mtimecmp = (riscv_machine_timer_t *)0x44004000;
- Setup the timer to generate the tick interrupts.
void vPortSetupTimer( void );
- Set the next interval for the timer
static void prvSetNextTimerInterrupt( void );
- Used to catch tasks that attempt to return from their implementing function.
static void prvTaskExitError( void );
void vPortEnterCritical( void )
portDISABLE_INTERRUPTS();
uxCriticalNesting++;
void vPortExitCritical( void )
uxCriticalNesting–;
if( uxCriticalNesting == 0 )
portENABLE_INTERRUPTS();
/* Sets the next timer interrupt
Reads previous timer compare register, and adds tickrate */
static void prvSetNextTimerInterrupt(void)
uint64_t time;
time = mtime->val_low;
time |= ((uint64_t)mtime->val_high << 32);
time += (configCPU_CLOCK_HZ / configTICK_RATE_HZ);
mtimecmp->val_low = (uint32_t)(time & 0xFFFFFFFF);
mtimecmp->val_high = (uint32_t)((time >> 32) & 0xFFFFFFFF);
/* Enable timer interrupt /
__asm volatile(“csrs mie,%0”::“r”(0x80));
/* Sets and enable the timer interrupt */
uint64_t time;
/* Enable timer interrupt */
__asm volatile("csrs mie,%0"::"r"(0x80));
/* A function that implements a task must not exit or attempt to return to
its caller as there is nothing to return to. If a task wants to exit it
should instead call vTaskDelete( NULL ).
Artificially force an assert() to be triggered if configASSERT() is
defined, then stop here so application writers can catch the error. */
configASSERT( uxCriticalNesting == ~0UL );
for( ;; );
/* Clear current interrupt mask and set given mask /
void vPortClearInterruptMask(int mask)
__asm volatile(“csrw mie, %0”::“r”(mask));
/* Set interrupt mask and return current interrupt enable register */
int vPortSetInterruptMask(void)
int ret;
__asm volatile(“csrr %0,mie”:"=r"(ret));
__asm volatile(“csrc mie,%0”::“i”(7));
return ret;
See header file for description.
StackType_t *pxPortInitialiseStack( StackType_t *pxTopOfStack, TaskFunction_t pxCode, void pvParameters )
/ Simulate the stack frame as it would be created by a context switch
interrupt. */
register int *tp asm(“x3”);
pxTopOfStack–;
pxTopOfStack = (portSTACK_TYPE)pxCode; / Start address */
pxTopOfStack -= 22;
pxTopOfStack = (portSTACK_TYPE)pvParameters; / Register a0 */
pxTopOfStack -= 6;
pxTopOfStack = (portSTACK_TYPE)tp; / Register thread pointer */
pxTopOfStack -= 3;
pxTopOfStack = (portSTACK_TYPE)prvTaskExitError; / Register ra */
return pxTopOfStack;
void vPortSysTickHandler( void )
/Save Context/
__asm volatile(“lw t0, pxCurrentTCB”);
__asm volatile(“sw a2, 0x0(t0)”);
/* Increment the RTOS tick. */
prvSetNextTimerInterrupt();
/*Switch task */
if( xTaskIncrementTick() != pdFALSE )
vTaskSwitchContext();
/*Restore Context*/
__asm volatile("lw sp, pxCurrentTCB");
__asm volatile("lw sp, 0x0(sp)");
__asm volatile("lw t0, 31 * 4(sp)");
__asm volatile("csrw mepc, t0");
__asm volatile("lw x1, 0x0(sp)");
__asm volatile("lw x4, 3 * 4(sp)");
__asm volatile("lw x5, 4 * 4(sp)");
__asm volatile("lw x6, 5 * 4(sp)");
__asm volatile("lw x7, 6 * 4(sp)");
__asm volatile("lw x8, 7 * 4(sp)");
__asm volatile("lw x9, 8 * 4(sp)");
__asm volatile("lw x10, 9 * 4(sp)");
__asm volatile("lw x11, 10 * 4(sp)");
__asm volatile("lw x12, 11 * 4(sp)");
__asm volatile("lw x13, 12 * 4(sp)");
__asm volatile("lw x14, 13 * 4(sp)");
__asm volatile("lw x15, 14 * 4(sp)");
__asm volatile("lw x16, 15 * 4(sp)");
__asm volatile("lw x17, 16 * 4(sp)");
__asm volatile("lw x18, 17 * 4(sp)");
__asm volatile("lw x19, 18 * 4(sp)");
__asm volatile("lw x20, 19 * 4(sp)");
__asm volatile("lw x21, 20 * 4(sp)");
__asm volatile("lw x22, 21 * 4(sp)");
__asm volatile("lw x23, 22 * 4(sp)");
__asm volatile("lw x24, 23 * 4(sp)");
__asm volatile("lw x25, 24 * 4(sp)");
__asm volatile("lw x26, 25 * 4(sp)");
__asm volatile("lw x27, 26 * 4(sp)");
__asm volatile("lw x28, 27 * 4(sp)");
__asm volatile("lw x29, 28 * 4(sp)");
__asm volatile("lw x30, 29 * 4(sp)");
__asm volatile("lw x31, 30 * 4(sp)");
__asm volatile("addi sp, sp, 4 * 32");
__asm volatile("mret");
uint32_t g_startscheduler = 0;
BaseType_t xPortStartScheduler( void )
vPortSetupTimer();
uxCriticalNesting = 0;
g_startscheduler = 1;
__enable_irq();
raise_soft_interrupt();
/*Should not get here*/
return pdFALSE;
void Software_IRQHandler(void)
if(1 == g_startscheduler)
g_startscheduler = 2; //skip the save n switch context first time when scheduler is starting.
/Save Context/
/*Restore Context*/
//PRCI->MSIP[0] = 0x00;
__asm volatile("addi sp, sp, -1*4");
__asm volatile("sw t0, 0(sp)");
__asm volatile("li t0, 0x44000000"); // address of PRCI->MSIP[0]
__asm volatile("sw zero,0(t0)");
__asm volatile("lw t0, 0(sp)");
__asm volatile("addi sp, sp, 1*4");
void vPortYield( void )
