rtel wrote on Monday, August 20, 2007:
> They build in the DOS box, but I can’t use their suggestion
> of a shortcut definition
> in the .gdbinit
I have not tried using an init file, but in the past I have found on a Windoze host that the file has to be called gdb.ini, rather than .gdbinit.
>file to replace the long (and, in the
> FreeRTOS doc, incorrect)
> command to connect to the controller that way.
What is incorrect with it?
> Here’s a test you can run: In a DOS box, run make to build
> the package.
Ok, here is my output.
C:\E\Dev\FreeRTOS\Demo\CORTEX_LM3S6965_GCC>make clean
CC startup.c
CC main.c
CC …/…/Source/list.c
CC …/…/Source/queue.c
CC …/…/Source/tasks.c
CC …/…/Source/portable/GCC/ARM_CM3/port.c
CC …/…/Source/portable/MemMang/heap_2.c
CC …/Common/Minimal/BlockQ.c
CC …/Common/Minimal/PollQ.c
CC …/Common/Minimal/integer.c
CC …/Common/Minimal/semtest.c
CC LuminaryDrivers/osram128x64x4.c
CC LuminaryDrivers/ustdlib.c
CC …/Common/Minimal/blocktim.c
CC …/Common/Minimal/death.c
CC ParTest/ParTest.c
CC timertest.c
CC webserver/emac.c
CC webserver/http-strings.c
CC webserver/httpd-cgi.c
CC webserver/httpd-fs.c
CC webserver/httpd.c
CC …/Common/ethernet/uIP/uip-1.0/uip/psock.c
CC …/Common/ethernet/uIP/uip-1.0/uip/timer.c
CC …/Common/ethernet/uIP/uip-1.0/uip/uip.c
CC …/Common/ethernet/uIP/uip-1.0/uip/uip_arp.c
CC webserver/uIP_Task.c
LD gcc/RTOSDemo.axf
>Run
> make *again*, as though you were rebuilding after changing
> one file (you don’t
> need to actually change any files for this test).
Ok, here is my output this time:
make: Nothing to be done for `all’.
> The second
> make will complain
> about missing dependencies. That’s because the case
> differences will be picked
> up by make from the automatically-generated gcc/*.d files.
Which version of make are you using? I am not using cs-make, but (I think) the one from the Cygwin directory.
