PugetBound wrote on June 14, 2019:
Fresh clone from github.com/aws/amazon-freertos, SetupAWS.py setup executed properly.
Here is current failed build output from make:
xxxxxxx@xxxxxxx-PC MINGW32 ~/esp/amazon-freertos/demos/espressif/esp32_devkitc_esp_wrover_kit/make
$ make
CC build/amazon-freertos-common/lib/bufferpool/aws_bufferpool_static_thread_safe.o
C:/Users/xxxxxxx/Downloads/Software/Tools/esp32_win32_msys2_environment_and_toolchain-20181001/msys32/home/xxxxxxx/esp/amazon-freertos/lib/bufferpool/aws_bufferpool_static_thread_safe.c:193:1: fatal error: opening dependency file lib/bufferpool/aws_bufferpool_static_thread_safe.d: No such file or directory
compilation terminated.
make[1]: *** [/home/xxxxxxx/esp/amazon-freertos/lib/third_party/mcu_vendor/espressif/esp-idf/make/component_wrapper.mk:286: lib/bufferpool/aws_bufferpool_static_thread_safe.o] Error 1
make: *** [/home/xxxxxxx/esp/amazon-freertos/demos/espressif/esp32_devkitc_esp_wrover_kit/make/…/…/…/…/lib/third_party/mcu_vendor/espressif/esp-idf/make/project.mk:477: component-amazon-freertos-common-build] Error 2
I see that the file aws_bufferpool_static_thread_safe.c is in that directory, is there a broken pointer somewhere?
PB
