netstv wrote on November 15, 2019:
Building Machine:
MacBook Pro
Catalina
OSX 10.15.1
I’ve gone through the “Getting Started with the Espressif ESP32-DevKitC and the ESP-WROVER-KIT” to configure the FreeRTOS demo applications. Did the AWS Command Line Interface, ran the configure (set my ssid, wifi, thing name,etc…)
Run the python SetupAWS.py setup with no errors.
Then I run
cmake -DVENDOR=espressif -DBOARD=esp32_wrover_kit -DCOMPILER=xtensa-esp32 -S . -B build
Then I change directories to the build directory…
make all -j4
Here is the console output that fails and I need help on…
start of console output
Scanning dependencies of target bootloader
[ 48%] Creating directories for ‘bootloader’
[ 48%] Building ASM object esp-idf/esp32/CMakeFiles/idf_component_esp32.dir/dport_panic_highint_hdl.S.obj
[ 48%] Building C object libraries/3rdparty/CMakeFiles/afr_3rdparty_mbedtls.dir/mbedtls/library/ctr_drbg.c.obj
[ 48%] Building C object esp-idf/esp32/CMakeFiles/idf_component_esp32.dir/esp_err_to_name.c.obj
[ 50%] No download step for ‘bootloader’
[ 50%] No patch step for ‘bootloader’
[ 50%] No update step for ‘bootloader’
[ 50%] Building C object esp-idf/nimble/CMakeFiles/idf_component_nimble.dir/nimble/nimble/host/src/ble_l2cap_coc.c.obj
[ 51%] Building C object esp-idf/esp32/CMakeFiles/idf_component_esp32.dir/esp_timer.c.obj
[ 51%] Performing configure step for ‘bootloader’
[ 51%] Building C object libraries/3rdparty/CMakeFiles/afr_3rdparty_mbedtls.dir/mbedtls/library/debug.c.obj
CMake Error at /Users/stepheniribarne/work/amazon-freertos/vendors/espressif/esp-idf/tools/cmake/idf_functions.cmake:24 (include):
include could not find load file:
components
Call Stack (most recent call first):
/Users/stepheniribarne/work/amazon-freertos/vendors/espressif/esp-idf/tools/cmake/project.cmake:5 (include)
CMakeLists.txt:19 (include)
[ 51%] Building C object libraries/3rdparty/CMakeFiles/afr_3rdparty_mbedtls.dir/mbedtls/library/des.c.obj
– Found Git: /usr/local/bin/git (found version “2.23.0”)
CMake Error at /Users/stepheniribarne/work/amazon-freertos/vendors/espressif/esp-idf/tools/cmake/idf_functions.cmake:42 (idf_set_target):
Unknown CMake command “idf_set_target”.
– Configuring incomplete, errors occurred!
make[2]: *** [esp-idf/bootloader-prefix/src/bootloader-stamp/bootloader-configure] Error 1
make[1]: *** [esp-idf/CMakeFiles/bootloader.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
end of console output
I don’t know what I’m missing. I followed the instructions (multiple times) very closely. I don’t know how to debug this. Any help would be greatly appreciated.
-stv
