I use the function xQueueSendFromISR to write data to a queue in an UART ISR of V850, the return result tells me write successfully,but when I use the function xQueueReceive read from the queue in a task,there is nothing. Why?
Have you stepped into the xQueueSendFromISR() and xQueueReceive()
functions to see what the functions think the state of the queue is?
The first thing to check would be that the queue handle passed as the
first parameter into both functions is the same. If so, look at the
structures in the debugger to look for discrepancies in the values of
the structure members or some obvious corruption. To see the queue
structures take the queue handle passed into the queue API functions and
cast them to the ( xQUEUE* ) type.
