adissida wrote on Tuesday, September 15, 2015:
The example projects I have looked at, its simple. To be more shure and understand the xQueue I have read the manual for it and this video guide https://www.youtube.com/watch?v=8lIpI30Tj-g
This is my code for setting up the interrupt handler:
INTC_register_interrupt((int_handler)&trvCLI_UART_ISR, AVR32_USART1_IRQ, AVR32_INTC_INT0);
then from the example project the portENTER_SWITCHING_ISR is needed:
__attribute((naked)) static void trvCLI_UART_ISR( void )
portENTER_SWITCHING_ISR();
trvCLI_UART_ISR_Recieve();
portEXIT_SWITCHING_ISR();
and at last this function is called after entering switching ISR:
__attribute((noinline)) static portBASE_TYPE trvCLI_UART_ISR_Recieve( void )
/* Now we can declare the local variables. */
signed portCHAR cChar = 0;
portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
unsigned portLONG ulStatus;
volatile avr32_usart_t *usart = trvCLI_USART;
/* What caused the interrupt? */
ulStatus = usart->csr & usart->imr;
if (ulStatus & AVR32_USART_CSR_RXRDY_MASK)
/* The interrupt was caused by the receiver getting data. */
cChar = usart->rhr; //TODO
/* Because FreeRTOS is not supposed to run with nested interrupts, put all OS
calls in a critical section . */
portENTER_CRITICAL();
if (xQueueSendFromISR(xRxedChars, &cChar, &xHigherPriorityTaskWoken))
gpio_tgl_gpio_pin(trvLED_GPS);
portEXIT_CRITICAL();
usart->csr;
/* The return value will be used by portEXIT_SWITCHING_ISR() to know if it
should perform a vTaskSwitchContext(). */
return ( xHigherPriorityTaskWoken );
I have a simple task, to watch the xRxedChars queue:
void trvUART_CLI_RX( void *pvParameters )
signed portCHAR receivedChars = 0;
uint8_t str[30];
( void ) pvParameters;
for ( ;; )
if (xQueueReceive(xRxedChars, &receivedChars, comRX_BLOCK_TIME))
sprintf( str,"%d",receivedChars );
trvCLI_WriteLine( &str );
//vTaskDelete(NULL);
As soon as I enter something in the console, everything hangs. If I change the xQueueReceive to xQueueReceiveFromISR it doesent hangs but the value is never copied to receivedChars.
Using ATMEL UC3, FreeRTOS V8.2.2
