Why is my task not found
For practice I use wokwiki to learn rtos on a ESP32.
This is my code :
#if CONFIG_FREERTOS_UNICORE
static const BaseType_t app_cpu = 0 ;
#else
static const BaseType_t app_cpu = 1;
// Pins
static const int led_pin = 2;
//Our task  blink a led
void toggleLed(void * parameter) {
  while(1) {
    digitalWrite(led_pin, HIGH);
    vTaskDelay(500 / portTICK_PERIOD_MS );
    digitalWrite(led_pin, LOW);
    vTaskDelay(500 / portTICK_PERIOD_MS);
void setup() {
  pinMode(led_pin, OUTPUT);
  // Task to run forever
  xTaskCreate(
    toggleLed,    // Function to be called
    "ToggleLed",  // name of the function
    1024,         // stack size
    NULL,         // parameter to pass to the function
    1,            // priority
    NULL         // task handle
  vTaskStartScheduler();
void loop() {
Shw
This is from a YT course of Shwan Hymel
But as soon as I compile it , I see this as output
E (1911) task_wdt: esp_task_wdt_reset(705): task not found
How to solve this ?
As documented here:
Unlike Vanilla FreeRTOS, users of FreeRTOS in ESP-IDF must never call vTaskStartScheduler() and vTaskEndScheduler() . Instead, ESP-IDF starts FreeRTOS automatically.
You are likely getting the watchdog timer expired because of the extra call to vTaskStartScheduler which prevents Arduino framework to manage it.
You can also refer to these examples.
oke
Changed the code to this :
#else
// Pins
  while(1) {
void setup() {
   xTaskCreatePinnedToCore(
    1024,         // stack size
    1,            // priority
    NULL ,        // task handle
    app_cpu
void loop() {
But still no luck
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1156
load:0x40078000,len:11456
ho 0 tail 12 room 4
load:0x40080400,len:2972
entry 0x400805dc
The part you have used in your diagram.json: "type": "board-esp32-devkit-c-v4" doesn’t seem to have a user LED at GPIO 2.
Your code should be working with: "type": "wokwi-esp32-devkit-v1".
Example
Thanks
Now I can finally work on this : https://www.youtube.com/playlist?list=PLEBQazB0HUyQ4hAPU1cJED6t3DU0h34bz
and the homework on lesson 2
is this a good way to make the led blink on different rates
#else
// Pins
void toggleLed1(void * parameter) {
  while(1) {
// homework to change the delay to another time
void toggleLed2(void * parameter) {
  while(1) {
    vTaskDelay(200 / portTICK_PERIOD_MS );
    vTaskDelay(200 / portTICK_PERIOD_MS);
void setup() {
    toggleLed1,    // Function to be called
    1024,         // stack size
    1,            // priority
    app_cpu
    toggleLed2,    // Function to be called
    "ToggleLed2",  // name of the function
    1024,         // stack size
    1,            // priority
    app_cpu
void loop() {
or can I improve the code ?
This isn’t the ideal way to make the LED blink at different rates. Issue is that you have two tasks trying to control a single shared resource, which is the LED; this can lead to a race condition.
Since the purpose of this Forum is to provide support related to FreeRTOS and its libraries, and the question seems like homework, I can’t comment further on this, but there are lots of resources online that can help you with this.
pity.
it is not homework because im not at school or something but a self thaught developer who wants to learn more about rtos but wants to be sure he really understands things and do not learn bad things or ways
The challenge was to make a second task that blinks the same led.
And what are you expecting to happen if two different tasks are telling the LED to do differrent things?
No idea, that I did not learned so far what could happen.
Till now I only learned to write tasks.
Sometimes its interesting to try to think ahead about what you would expect to happen.
I would think that one of the two would win.
But who would be winning , I have no idea
Or that the led will go on and after a very very short time will go off or the other way around.
So I think it leads to undefined behaviour as you call it
Right. And as you likely have figured by now, if you want to blink one LED at a specific rate, it does not make sense to have 2 tasks do that.
