I have to make code that contains 2 tasks.
One that blink the build_in led with a delay
One that reads a number from the serial monitor that can change the delaytime of the built in led
So I have this :
// my solution to lesson 3
// Learned so far
// - writing task
// - task scheduling
// Challenge
// Write 2 tasks.
// On to display a led and one where a user can enter a number which delays the blinking
#if CONFIG_FREERTOS_UNICORE
static const BaseType_t app_cpu = 0 ;
#else
static const BaseType_t app_cpu = 1;
// Pins
static const int led_pin = 2;
int delayTime = 500;
//Our task blink a led
void toggleLed(void * parameter) {
while(1) {
digitalWrite(led_pin, HIGH);
vTaskDelay(delayTime / portTICK_PERIOD_MS );
digitalWrite(led_pin, LOW);
vTaskDelay(delayTime / portTICK_PERIOD_MS);
// Our task is to read in a number
void changeBlinkRate(void * parameter) {
char ch;
char buff[20];
int idx;
//clear the buffer
memset(buff, 0, 20);
if (Serial.available() > 0) {
ch = Serial.read();
if (ch == '\n') {
delayTime = atoi(buff);
Serial.print("Updated LED delay to: ");
Serial.println(delayTime);
// clear buffer
idx = 0 ;
} else {
if (idx < 19) {
buff[idx] = ch;
idx++;
void setup() {
pinMode(led_pin, OUTPUT);
Serial.begin(9600);
Serial.println("RW");
// Task to run forever
xTaskCreatePinnedToCore(
toggleLed, // Function to be called
"ToggleLed", // name of the function
1024, // stack size
NULL, // parameter to pass to the function
1, // priority
NULL , // task handle
app_cpu
changeBlinkRate, // Function to be called
"ChangeBlinkRate", // name of the function
1024, // stack size
1, // priority
app_cpu
void loop() {
But on wokwiki I do not see the serial monitor appear and the led does not blink.
So what I did not understand.
Till now I learned only about writing task and task priority
Tasks are normally implemented as an infinite loop; the function which implements the task must never attempt to return or exit.
Instead of the current logic, it should be an infinite loop similar to the LED task, where it checks for serial data and processes its once its available.
// Learned so far
// - writing task
// Challenge
// Write 2 tasks.
#else
// Pins
while (1) {
char ch;
char buff[20];
int idx;
while (1) {
//clear the buffer
ch = Serial.read();
if (ch == '\n') {
// clear buffer
idx = 0 ;
} else {
if (idx < 19) {
buff[idx] = ch;
idx++;
void setup() {
Serial.begin(9600);
1024, // stack size
1, // priority
NULL, // task handle
app_cpu
1024, // stack size
1, // priority
app_cpu
void loop() {
Still no blinking and the serial monitor is not visible
I don’t think it will automatically create a serial monitor, intead I think a serial monitro needs to be attached to your ESP32 via wokwi UI, I might be wrong here as I haven’t used wokwi before.
Your code seems to be working and it’s updating the `delayTime`, however wokwi seems to not be refreshing the LED status fast enough to see the blinks for higher blink frequencies (lower delayTime).
I can see the delay getting doubled when delayTime is set to 1000.
