vTaskStartScheduler() error
hello I’m getting started with freeRTOS
I’ve been trying to blink an led with a delay of 1sec but whenever I include vTaskStartScheduler() function the led blinks faster than the delay period what might be the problem ,here is my code
#include <stdio.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include"freertos/FreeRTOSConfig.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
/* Can use project configuration menu (idf.py menuconfig) to choose the GPIO to blink,
   or you can edit the following line and set a number here.
#define BLINK_GPIO 1
void blink_1(void *parameters){
while(1) {
        /* Blink off (output low) */
        printf("Turning off the LED\n");
        gpio_set_level(BLINK_GPIO, 0);
        vTaskDelay(1000 / portTICK_PERIOD_MS);
        /* Blink on (output high) */
        printf("Turning on the LED\n");
        gpio_set_level(BLINK_GPIO, 1);
void app_main()
    /* Configure the IOMUX register for pad BLINK_GPIO (some pads are
       muxed to GPIO on reset already, but some default to other
       functions and need to be switched to GPIO. Consult the
       Technical Reference for a list of pads and their default
       functions.)
    gpio_pad_select_gpio(BLINK_GPIO);
    /* Set the GPIO as a push/pull output */
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
      xTaskCreatePinnedToCore(blink_1,"blink_1",1024,NULL,configMAX_PRIORITIES-1,NULL,0);
     // xTaskCreate(blink_2,"blink_2",1024,NULL,0,NULL);
      vTaskStartScheduler();
thanks
Hi Joseph,
The issue is that the scheduler has already started before app_main is called. The solution is to comment out the call to vTaskStartScheduler();
See [TW#17310] xTaskCreate -> Guru Meditation Error of type InstrFetchProhibited occurred on core 0. (IDFGH-1540) · Issue #1457 · espressif/esp-idf · GitHub.
Thanks ,commenting out the call worked
