Thank you Hartmut for your answer. I have read the API before but it became clear to me after lunch, that only because LastWakeTime is not defined as a pointer*, the function vTaskDelayUntil just takes the address& of LastWakeTime for comparison, instead of passing the value. This probably saves memory space and computation time.
The reason the LastWakeTime parameter is passed via a pointer is that vTaskDelayUntil updates its value with each call.
Basically, what vTaskDelayUntil does is update the LastWakeTime by adding its time to delay parameter, then waits for that time stamp to arrive, or returns immediately if that time stamp has already passed.
