I am using FreeRTOS to modify the existing port of AUDO 1782 to towards the AURIX TC3xx.
I found strange behavior when I use the vTaskDelayUntil function.
Problem was that, only highest prio task was being activated continuously, without actual delay, and other tasks are in ready state forever.
When I debugged the vTaskDelayUntil (obviously I checked the port.c several times), I found position of the below code line in bold as suspicious.
void vTaskDelayUntil( TickType_t * const pxPreviousWakeTime, const TickType_t xTimeIncrement )
/* Update the wake time ready for the next call. */
** *pxPreviousWakeTime = xTimeToWake;**
if( xShouldDelay != pdFALSE )
traceTASK_DELAY_UNTIL( xTimeToWake );
/* prvAddCurrentTaskToDelayedList() needs the block time, not
the time to wake, so subtract the current tick count. */
prvAddCurrentTaskToDelayedList( xTimeToWake - xConstTickCount, pdFALSE );
mtCOVERAGE_TEST_MARKER();
As this line always gets executed whenever this function gets called, this would modify the value at pxPreviousWakeTime even if it was not the time to awake (which is xShouldDelay= pdTrue).
This works when I moved this line inside true path of ** if( xShouldDelay != pdFALSE ) ** as below and then the behaviour was as expected.
As I said, I am not having complete overview of the implementation, need to seek other’s opinion here…
Below is the complete modified function:
#if ( INCLUDE_vTaskDelayUntil == 1 )
TickType_t xTimeToWake;
BaseType_t xAlreadyYielded, xShouldDelay = pdFALSE;
configASSERT( pxPreviousWakeTime );
configASSERT( ( xTimeIncrement > 0U ) );
configASSERT( uxSchedulerSuspended == 0 );
vTaskSuspendAll();
/* Minor optimisation. The tick count cannot change in this
block. */
const TickType_t xConstTickCount = xTickCount;
/* Generate the tick time at which the task wants to wake. */
xTimeToWake = *pxPreviousWakeTime + xTimeIncrement;
if( xConstTickCount < *pxPreviousWakeTime )
/* The tick count has overflowed since this function was
lasted called. In this case the only time we should ever
actually delay is if the wake time has also overflowed,
and the wake time is greater than the tick time. When this
is the case it is as if neither time had overflowed. */
if( ( xTimeToWake < *pxPreviousWakeTime ) && ( xTimeToWake > xConstTickCount ) )
xShouldDelay = pdTRUE;
/* The tick time has not overflowed. In this case we will
delay if either the wake time has overflowed, and/or the
tick time is less than the wake time. */
if( ( xTimeToWake < *pxPreviousWakeTime ) || ( xTimeToWake > xConstTickCount ) )
//*pxPreviousWakeTime = xTimeToWake; /* TODO: Ashok: Modified code */
xAlreadyYielded = xTaskResumeAll();
/* Force a reschedule if xTaskResumeAll has not already done so, we may
have put ourselves to sleep. */
if( xAlreadyYielded == pdFALSE )
portYIELD_WITHIN_API();
#endif /* INCLUDE_vTaskDelayUntil */
