martin_cibulski wrote on Friday, February 08, 2008:
I’m programming a motor controller in a task.
To have a constant schedule for my controller I use the vTaskDelayUntil function.
But I found that my controller worked much too fast.
So I wrote some test code into my task to find out how long vTaskDelayUntil actually waits.
(I don’t show all code to keep my posting small)
#define MOT_TASK_PERIOD ((portTickType)100)
portTASK_FUNCTION (task_mot, pParameters __attribute__ ((unused)))
static portTickType xLastWakeTime = 500;
int nMot;
MOTOR* pMot;
int nSpeedStep;
int nTick1, nTick2;
DEBUG_LINE ("task_mot(.)");
i2c_init (MOT_I2C_BUS_NO, MOT_I2C_KHZ);
mot_init ();
while (1) {
nTick1 = xTaskGetTickCount();
vTaskDelayUntil (&xLastWakeTime, MOT_TASK_PERIOD);
nTick2 = xTaskGetTickCount();
When I debug the task and stop behind these statements, the variables
have the following values:
nTick1 3 (OK, only 3 milliseconds since system start)
xLastWakeTime 600 (which is 500 + MOT_TASK_PERIOD)
nTick2 3 (should be at least 600)
Why is nTick2 not 600 or more ?
vTaskDelayUntil should wait until 600 Ticks have been counted, right ?
I use FreeRTOS 4.7.1 on an LPC2148 with GCC.
The same happened with an earlier release (4.5 ?).
What did I do wrong here ?
Thanks for help,
Martin
