andreas_s_ wrote on Monday, April 24, 2006:
has anybody tried to run FreeRTOS in GDB’s ARM simulator? One potential problem I see is that FreeRTOS uses SWI, but this is already used by the simulator to communicate with the target.
Andreas
Andreas
nobody wrote on Monday, April 24, 2006:
I have stepped through a few things using the Insight simulator.
If you are using a simulator, why is the SWI used to communicate with a target? When simulating there is no connection to the target.
I meant: SWI is used to communicate between simulated software and simulator, e.g. for writing to stdout.
