hi all,
Is there any documentation available for the official freertos simulator for win-32.
I have gone through the page on the freertos website explaining :
1. Principals of Operation
2. Items to Note Before Using the Simulator
3. Source Code Organisation
4. Using the Eclipse / MingW (GCC) Demo
5. The Demo Application
6. Defining and Using Simulated Interrupt Service Routines
The .zip file has all the code and projects that just build and work so that is the way to get started. If you mean you want to learn more about the implementation I suggest running it and stepping through the code.
and running the demo program using the simulator just prints
ok 250
ok 500
etc.
Which - as per the documentation page you referenced before, means you have it running, and it is running correctly.
how could I get a more detailed information on the simulation.
Can you be more specific about what you want to know? You have read the documentation page, which provides information, over and above that, you have all the source code and a debugger, so can see what it is doing. The port layer for the simulator is very thin.
Is there a difference between using the simulator and using the arm-gdb?
the tracecon utilities were also provided may be using them can provide me with more information.
but there is no trace.bin file produced after the simulation
Well, yes, lots. For example:
Running on ARM you are running in real time, and using the interrupt mechanism provided by the hardware.
Running in the simulator you are not going to get real time performance, and there is no underlying hardware interrupt mechanism. Interrupt processing is simulated by using high and low priority windows threads.
Well the GDB simulator is simulating an ARM architecture - I don’t know how far it goes in that because I have not used it in a long time. It is in effect simulating the execution of ARM instructions in an x86 environment. Running the kernel in the GDB simulator (if that is possible) is not simulating the execution pattern of a FreeRTOS application, it is simulating running an ARM binary on an x86 computer.
The Windows simulator is simulating the execution pattern of a a real time scheduler, it is not simulating the execution of instructions in a non-native hardware environment.
With regards to tracecon - I have not used it with the Windows simulator. I cannot think of any reason off the top of my head why it would not work, although the timing information the trace contained would be a bit weird potentially. However, the tracecon utility has been legacy for a long time - I would recommend using the trace macros instead.
That was helpful. But, is there a way to simulate peripherals? (i feel embedded system application simulation is incomplete without simulating peripherals)
If that was your question, why is that not what you asked?
If you want to simulate ARM peripherals then you will have to either extend the windows simulator somehow, which will be very difficult because it is not running ARM instructions so will never be accurate (although it does provide an interrupt simulation mechanism). More realistically you will need to run an ARM simulator under windows, like quemu or the simulator found in Keil and IAR tools. GDB does not simulate peripherals, only the core, I think.
I think you are confusing what has already been said about the difference between a platform that allows you to run FreeRTOS applications in a windows environment and a platform that is simulating another bit of hardware.
