nobody wrote on Thursday, May 26, 2005:
I am trying to use Embest IDE to compile and run the example program in the FreeRTOS. However, I am running into some link errors. Has anybody else used the Embest IDE for FreeRTOS?
Below are the error messages that I am receiving. If anybody has any suggestions, please let me know.
Regards,
--------------------Building project: rtosdemo516 ---------------------
arm-elf-gcc -mlittle-endian -gdwarf -c -I…\…\…\targets\at91 -IC:\EmbestIDE\Examples\at91\rtosdemo516\FreeRTOS\Demo\Arm7_at91fr40008_gcc
-IC:\EmbestIDE\Examples\at91\rtosdemo516\FreeRTOS\Source\include -IC:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\include
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\BlockQ.c -o.\debug\BlockQ.o
arm-elf-as -gdwarf2 --defsym AT91R40807=1 --defsym AT91EB40=1 --defsym AT91_DEBUG_ICE=1 -I…\…\…\targets\at91
-I…\…\…\targets\at91\targets\eb40 -I…\…\…\targets\at91\parts\m40800 C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\boot.s
-o.\debug\boot.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\comtest.c -o.\debug\comtest.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\death.c -o.\debug\death.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\dynamic.c -o.\debug\dynamic.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\flash.c -o.\debug\flash.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\flop.c -o.\debug\flop.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Source\portable\MemMang\heap_2.c -o.\debug\heap_2.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\integer.c -o.\debug\integer.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Source\list.c -o.\debug\list.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\main.c -o.\debug\main.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\ParTest\ParTest.c -o.\debug\ParTest.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\PollQ.c -o.\debug\PollQ.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Source\portable\GCC\ARM7_AT91FR40008\port.c -o.\debug\port.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Source\portable\GCC\ARM7_AT91FR40008\portISR.c -o.\debug\portISR.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Source\queue.c -o.\debug\queue.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\Common\Minimal\semtest.c -o.\debug\semtest.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\serial\serial.c -o.\debug\serial.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\serial\serialISR.c -o.\debug\serialISR.o
C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Source\tasks.c -o.\debug\tasks.o
arm-elf-ld -T…\…\…\targets\at91\targets\sram_ice.ld -L…\…\…\Build\xgcc-arm-elf\arm-elf\lib -L…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2
-o.\debug\rtosdemo516.elf .\debug\boot.o .\debug\BlockQ.o .\debug\comtest.o .\debug\death.o .\debug\dynamic.o
.\debug\flash.o .\debug\flop.o .\debug\heap_2.o .\debug\integer.o .\debug\list.o .\debug\main.o .\debug\ParTest.o
.\debug\PollQ.o .\debug\port.o .\debug\portISR.o .\debug\queue.o .\debug\semtest.o .\debug\serial.o
.\debug\serialISR.o .\debug\tasks.o …\…\…\targets\at91\drivers\lib_drv\arm-inter\lib_drv_32.lib …\…\…\targets\at91\parts\r40807\arm-inter\r40807_lib32.lib
-lc -lgcc
.\debug\boot.o:C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\boot.s:113: undefined reference to `__bss_beg__’
.\debug\boot.o:C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\boot.s:113: undefined reference to `__data_beg__’
.\debug\boot.o:C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\boot.s:113: undefined reference to `__data_beg_src__’
.\debug\boot.o:C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\boot.s:113: undefined reference to `__data_end__’
.\debug\boot.o:C:\EmbestIDE\Examples\at91\rtosdemo516-2\FreeRTOS\Demo\ARM7_AT91FR40008_GCC\boot.s:113: undefined reference to `__stack_end__’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(__main.o): In function `__do_global_ctors’:
__main.o(.text+0xc4): undefined reference to `atexit’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `size_of_encoded_value’:
unwind-dw2-fde.o(.text+0x5c): undefined reference to `abort’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `read_encoded_value_with_base’:
unwind-dw2-fde.o(.text+0x1d8): undefined reference to `abort’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `__register_frame’:
unwind-dw2-fde.o(.text+0x274): undefined reference to `malloc’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `__register_frame_table’:
unwind-dw2-fde.o(.text+0x32c): undefined reference to `malloc’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `__deregister_frame_info_bases’:
unwind-dw2-fde.o(.text+0x3e4): undefined reference to `free’
unwind-dw2-fde.o(.text+0x41c): undefined reference to `abort’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `__deregister_frame’:
unwind-dw2-fde.o(.text+0x450): undefined reference to `free’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `base_from_object’:
unwind-dw2-fde.o(.text+0x4b4): undefined reference to `abort’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `get_cie_encoding’:
unwind-dw2-fde.o(.text+0x4e8): undefined reference to `strlen’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `start_fde_sort’:
unwind-dw2-fde.o(.text+0x1274): undefined reference to `malloc’
unwind-dw2-fde.o(.text+0x1298): undefined reference to `malloc’
…\…\…\Build\xgcc-arm-elf\lib\gcc-lib\arm-elf\3.0.2/libgcc.a(unwind-dw2-fde.o): In function `end_fde_sort’:
unwind-dw2-fde.o(.text+0x1350): undefined reference to `free’
unwind-dw2-fde.o(.text+0x138c): undefined reference to `abort’
unwind-dw2-fde.o(.text+0x1390): undefined reference to `abort’
Error executing above command.
